M/T Drag radial vs. ET Street non radial
Originally Posted by BERGN8R
I'm looking for feedback on running M/T ET Streets instead their drag radials.
New 275/40/17 on C5 OEM 17 x 8.5 Magnesium wheels = 1.49 60'
Worn out 26 x 11.50 x 16" Mt ET Street on a 16 x 10 CCW drag pack = 1.51 60'
New 26 x 11.50 x 17" Mt ET Street on an PWO Y2K 5 spoke 17 x 8.5 = 1.53 60'
New 345/30/18 bfg dr on HRE 545 18 x 12 wheel = 1.52 60'
I have over 150 passes on these set-ups together and at different tracks....
I find the DRs better..........more stable at speed and I have driven them 450+ miles one way to race w/o issue.
I do not have a tire fetish
Originally Posted by ALLTHROTTLE&NOBOTTLE
On my 97' I have gotten my best 60' time on MT ET Street........RADIALS!
I ran both tires on my Z06.
I had the same ET's with both tires, but I was way, way more consistent with the ET Streets. If you plan on getting a second set or rims, I'd go with the ET Streets. If you don't like the hassle of swapping tires at the track, then get the DR's.
One thing to think about is that if you run ET Streets without skinnies up front, the car gets a little squirley at the top end. It's no big deal, but you can feel it.
ET Streets are cheaper too. I think mine were $160 each. I'm sure I just confused you even more, sorry.
Dave
Dave
Cruise-In II & IV Veteran
CI VI Drag Champ!
I have them both as well. ET is little if any difference
Pressures on each at diffent as the bias I run aroind 12 and the radial aournd 15
Car does feel more stable throughout
Any difference in overall ET?
Will know about dr vs street next month.
Will also know how skinnys on the front and dr combos on the back work...........should be just fine
Keep in mind that the ET Streets are slightly lighter than the ET Street (or most any other) Drag Radials as well.
It definitely helps to run the skinnies (full CCW drag pack etc.) if you're running bias ply (ET Streets) in the back but it's not mandatory if you're a decent driver.
Originally Posted by YO-EL
Don't you need to run front skinnies with the ET streets though??
(Where you can run your regular rims/tires with the drag radials....)
I run Et Streets w/ my daily driver tires up front at the track & the ONLY time it felt loose on the top end was if I dropped the rear PSI to below 17psi...and that only required some steering at the end of the run...mild steering....
I absolutely got more consistent when I went from DR's to ET Streets. I lost 1-2mph though due to the slightly taller tire, but ET was very close. I would not switch back!!!
Ron
Ron
When I had my 99 LPE Vette I cut a 1.42 60ft on both tires. Ran a 26x10x15in tire. They both hooked great for me. And yes I could break parts with BOTH tires.
I was hoping the ET streets being 5 lbs lighter each and about 1" taller would provide more benefit. It looks like its marginal.
My street setup:
HRE 18 x 9.5 545 w/ clear center +58mm w/ 275/35/18 BFG KDWs 52 lbs ea.
HRE 18 x 12 545 w/ clear center +74mm w/ 345/30/18 BFG DRs 57lbs ea.
Best so far 10.97@122.25, 1.528 60', DA -775
My CCW drag pack:
CCW drag pack rear 16 x 10 classic full polished with well worn MT ET Street 26 x 11.50 x 16 (1/32” tread) with center caps 34 lbs ea.
CCW drag pack front 16 x 5 classic full polished with like new Firestone deluxe champion 5.00/5.25-16 (10/32” tread) with center caps 33 lbs ea.
Best so far 10.87@125.42, 1.538 60', DA -790
So loosing 84 lbs of rotating mass gets ya about 1/10th.
Results may vary
Originally Posted by BlackRoseLT1
What PSI are you guys running in the ET Streets:
on the track?
on the street? (I'll be driving to the track on mine.)
Thanks,Dave
on the track?
Thanks,Dave
At the track:
BFG drs or Bias.......15-19 psi hot depending on track prep/air temp
MT ET Street Radial.......so far 20-24 psi hot.......yep 1.49 60'
On the street either dr or bias I run 25-28 psi hot depending on the weather
on the track?
Thanks,
Dave
on the track?
Thanks,
Dave
ET Streets 30 psi to drive to the track. I go down to about 19 psi to start & adjust from there. Cars w/ a lot more HP will usually go lower for more traction. With slipping the clutch, I find it hard to spin the ET streets on the launch with a decent track prep, and that's with launching @ 5800-6400rpm's...
Others may differ.
Ron
Others may differ.
Ron
