Drag Racing Results, Trap Speed, Reaction Time, Driving Technique, Tips for Running the Corvette in the ¼ & 1/8 mile, Events
Slicks without tubes?
Old Apr 13, 2006 | 06:28 PM
Pug's Avatar
Pug
St. Jude Donor '08
Default Slicks without tubes?
Is this safe?
I just broke down my second hand MT 29.5 x 13.5 x 15 slick as I thought I had a hole in the tube only to find out it was the valve stem leaking and no tube there.
I have made umpteen passes on these and now should I be thanking my lucky stars or is running without a tube ok?
Old Apr 13, 2006 | 06:33 PM
16Again's Avatar
16Again
St. Jude Donor '07-'12, '20
No tubes in mine, no problems either. Hopefully i'm understanding this correctly, your running ET Streets right?
Old Apr 13, 2006 | 06:34 PM
mackeyred96's Avatar
mackeyred96
From: Former NCM Drag Racing coordinator, National director Corvette Challenge Spring Hill, Tennessee: Whiting, New Jersey
Cruise-In VI Veteran
Cruise-In VII Veteran
Most run them tubless.
Old Apr 13, 2006 | 06:37 PM
Pug's Avatar
Pug
St. Jude Donor '08
ET drags.
Old Apr 13, 2006 | 07:15 PM
Glensgages's Avatar
Glensgages
.... while they are completely safe to run without tubes (S&W sold me my old dragster w/o tubes, saying they 'weren't necessary' ), you may find they'll leak between race-days without tubes:
it is strictly preference.....
Old Apr 13, 2006 | 07:17 PM
16Again's Avatar
16Again
Originally Posted by Pug
ET drags.
Your fine with no tubes
Old Apr 13, 2006 | 08:41 PM
98NYFINESTVETTE's Avatar
98NYFINESTVETTE
From: 10.70 @ 124mph, Stock Bottom End @ 3620lbs, ECS Racing Team Member. The 1st NMCA LSX Index Rumble World Champion. 2011,12,13 Champion
Is this safe?
You are crazy to run a slick w/o a tube. Good Luck.
Old Apr 13, 2006 | 08:42 PM
mackeyred96
There are certain racing applications where tubes do help, especially in classes with Pro Trees where you want very little tire deflection on launch. Tubes add to stiffen the sidewalls of the tires and the car will react faster.
Old Apr 13, 2006 | 09:01 PM
Pug's Avatar
Pug
St. Jude Donor '08
The track prep here sux so I think I need all I can get for the 60'
So far my 60's have been in the 1.41 range and if I had a stiffer sidewall the 60' may not be as good due to the crappy track.
Old Apr 13, 2006 | 09:11 PM
Pug's Avatar
Pug
St. Jude Donor '08
BTW this is for my race truck with best times of low to mid 11's N/A and high 9's to low 10's on a little juice @5500' DA.
Here is a pic of her in street trim.
Old Apr 14, 2006 | 02:51 AM
Face's Avatar
Face
I had to install tubes in mine. I was spinning the tires on the rim at least a 1" after every pass. Then on one pass, one bead spun and the other didn't, the wheel was cocked and pulling the whole pass so I let off. It's easy for a bead to break at the top end when this happens.
So needless to say, afterwords I ordered a screw kit and tubes and couldn't feel safer. The only difficult part was finding the courage to drill into a set of $500 wheels.
And as Mackey mentioned, your R/T's will change. I went from a little late on the light to a little early. :bb
Old Apr 14, 2006 | 08:58 AM
chaase's Avatar
chaase
St. Jude Donor '12
I ran slicks w/o tubes in my old firebird. My friend ran his camaro w/o tubes... No problems to speak of besides losing air between track days.
Chris
To Slicks without tubes?
