Drag Strip: Helmet Rules???
Guest
Posts: n/a
Looks like NHRA will allow "Pure Stock" verts down to 11.5 with no roll bar.
I see that's dated 2004. Wonder if it was retracted?
http://nhra.com/2004/news/june/062202.html
I see your sig says "auxilliary hardtop". If this is the case and you have the top on at the track, I believe you'll be held to the same rules as coupes (ie. no cage required unless below 11.50).
It amazes me that people are looking for ways to cheap out on safety equipment! Buy the SA helmet - it is fabricated to take multiple hits - like on a roll bar - as compared to a M helmet that is designed to take 1 impact - then skid or slide. The SA will also have fire protection in the lining.
As for roll bar or no roll bar - i guess it's your life - you make the call. honestly a good roll cage, helmet and firesuits are cheap in comparison to what you pay for the car and the enhancers, I guess I've seen one to many bad things happen - for me, I won't race a car without a roll bar, at least 5 points belts, - and never without the proper helmet and fire suit - because i know sooner or later someone or something will screw up or go blamo, and even if it's not my fault - my health or even my life will be on the line. And i will walk away!
carl "yeah i've been called the safety **** - whats your point? " Johansson
