Drag Racing Results, Trap Speed, Reaction Time, Driving Technique, Tips for Running the Corvette in the ¼ & 1/8 mile, Events
Carroll's Rod & Racecraft bolt-in straight axle kit.
Old 04-09-2008, 09:59 PM
  #181
tensecvet
tensecvet's Avatar
Thanks to the guys at Carrolls Rod & Racecraft . tested. This is the " Fastest Bolt-in C4 kit in the world "
Thanks Eddie Monari , you built a great racecar, with the BEST parts out there.. Thxs to all involved.
Maybe time for a new fresh thread
Old 04-10-2008, 10:19 AM
  #182
QuikZilver
QuikZilver's Avatar
Congrats! Look forward to hearing your times!
Old 04-10-2008, 09:07 PM
  #183
eddie the kid
eddie the kid's Avatar
thanks leo and bob (carrolls rod and racecraft) the c4 went like it was on railroad tracks
Old 04-11-2008, 12:55 PM
  #184
1996LT1
1996LT1's Avatar
This thread has been pretty amusing...most often quite sad, but amusing at the same time
Old 04-04-2013, 02:53 PM
  #185
NitrousSam
Support Corvetteforum!
NitrousSam's Avatar
For those who have installed the solid rear end system from Carroll's Rod and Racecraft,
I am curious how large of a wheel and tire combination you have been able to install. If you have photos of the rear I would appreciate it if you posted a couple. I spoke with Bob Carroll a couple of times and he is a super nice guy and I am seriously considering buying his package instead of building my own. Thanks!
Old 04-04-2013, 03:36 PM
  #186
DOUG @ ECS
Premium Supporting Vendor
DOUG @ ECS's Avatar
Location: Providing the most proven supercharger kits for your C5/6/7 609-752-0321
Received 1,085 Likes on 656 Posts
One of our customers run 28" tall 315's with probably more room to go with this set up, sorry I cant give a better answer.
Regardless it's weird to see a post from Mike pulled up...
Old 04-04-2013, 08:39 PM
  #187
ralph
ralph's Avatar
I'm not running running Boddy's setup, but something similar. The rear end is not the issue, it's the distance between the frame and the fender well. The 4-link might narrow the space slightly, but not much. I run a 325x50x15 which i also ran with the IRS. Certain tires (like mine) will stick out from under the fender slightly, so I use Grandsport flares to keep the tire covered. A 28x10.5 slick will fit, the 11.5 might need to flares. The Ws wont fit. I assume you could use a narrower and taller (30") tire as well. My tires are pretty big, but if you're plans include a huge tire, you're going to have to altering the frame.
Old 04-04-2013, 09:41 PM
  #188
NitrousSam
NitrousSam's Avatar
Thank You! Do you have any photos that you could post?
Sam
Old 04-04-2013, 09:42 PM
  #189
NitrousSam
NitrousSam's Avatar
Thanks! This is great info.
Sam
Old 04-05-2013, 12:43 AM
  #190
REDC4CORVETTE
REDC4CORVETTE's Avatar
If you run the weld wheels you need a 71/2 back spacing a 28 inch tire and 10 1/2 wide is max you can install under the car,you run the MT slicks ,if you use the DR you can put a 335 with no problem.Don't worry about the width of the tire that is why you are installing the 4 link ,the tires will grip even at a bad track.Oh on the MT Drag Slicks you have to make sure you buy the MT with the (S) for stiff side wall or the wheel will buckel under and hit the wheel .I have made all the mistakes
If you want the car to stay on the ground in the front you have to install QA1's and start at 5 clicks in you run 700 hp to 1 k like I was.
Old 04-05-2013, 04:59 AM
  #191
mackeyred96
mackeyred96's Avatar
Location: Former NCM Drag Racing coordinator, National director Corvette Challenge Spring Hill, Tennessee: Whiting, New Jersey
Cruise-In VI Veteran
Cruise-In VII Veteran
That's what I ran with mine. I had a 11.5 slick and the car
never spun the tires with low 1.3 60'.
Old 04-05-2013, 11:15 PM
  #192
NitrousSam
NitrousSam's Avatar
Great info - thanks a ton!
Old 04-05-2013, 11:17 PM
  #193
NitrousSam
NitrousSam's Avatar
Joh, - Thanks again and I appreciate your Facebook message as well!
Old 04-06-2013, 02:36 AM
  #194
REDC4CORVETTE
Long time no see !Broke down and bought a 2008 nowI am a c6 monster love the car.
Old 04-06-2013, 10:31 PM
  #195
NitrousSam
NitrousSam's Avatar
Long time for sure and life is good!!! You and I are thinking alike once again, I have a 2008 Z06 as well.
Quick Reply: Carroll's Rod & Racecraft bolt-in straight axle kit.
