PSi in drag radials on the street
Location: 10.70 @ 124mph, Stock Bottom End @ 3620lbs, ECS Racing Team Member. The 1st NMCA LSX Index Rumble World Champion. 2011,12,13 Champion
I set my Hoosiers and Nittos @ 30 to 32 when I leave the track to drive home.
I've driven there and home...about 30 miles.. on 15 to 18lbs. these days I dont even bother to pump em up.. I had the tires for 2 seasons now... and go to the track about once a month
I can tell you this. I drove home from the track without adding air to the tires due to the air station not working. WHAT A RIDE!! I was swaying all over due to the soft side wall. If I had to change lanes quickly or go into a turn - I would probably not make it. It is that bad of a ride (unsafe) to drive with the tire pressure so low. Have you ever drove a car with one tire low on air?
Location: Brentwood World's first A6 in the 9's (including N/A, blower, turbo and nitrous cars) 9.950@139.267 CA
The other thing about these tires is that they don't last very long if you put a lot of street miles on them.
I race at least once a week (on average) and usually get around 3-4 months out of a set but with my prior ones I drove to the track with them already mounted and they were thread bare after only just two months.
I drive on MT radials every day @ 20psi. I really dont drive the car everyday but I put about 200 - 300 miles a week on her @ 20 PSI. I like to play on the street so I leave them at a pressure where I can hook up...
