Drag Racing Results, Trap Speed, Reaction Time, Driving Technique, Tips for Running the Corvette in the ¼ & 1/8 mile, Events
3.07 to 3.54 Gains?
Old 04-29-2002, 10:59 PM
ex-gold87
ex-gold87's Avatar
Default 3.07 to 3.54 Gains?
Just made the Dana 36 to 44 swap with 3.54 gears. I know several of you have had to make this swap, what gains have been seen in the 1/8 and 1/4 mile.
Old 04-29-2002, 11:49 PM
DragMan
DragMan's Avatar
Cruise-In VII Veteran
Default Re: 3.07 to 3.54 Gains? (ex-gold87)
I also would like to know gains and 60 ft times with both!!
[Modified by DragMan, 10:52 PM 4/29/2002]
Old 04-30-2002, 12:08 AM
Beach Bum
Beach Bum's Avatar
With your set-up... I don't know... but show me your torque curve and I can probably make a fairly close guess.
With TPI motors the et improvement from 3.07 to 3.54 is very little if any. I think some have picked up a bit if they were running the stock torque converter. If you were already running a good converter, the gain is minimal at best.
However, those flat torque curved rev happy LT-1, LS-1 and most carb motors love it and would probably pick-up 1-2 tenths.
I went from 3.07 to 3.45 and improved "zero"...... I cryed. :cry
good luck
Beach
Old 04-30-2002, 12:12 AM
Mr Mojo
Elite Torch Red Member
Support Corvetteforum!
Mr Mojo's Avatar
Cental/South NJ Events Coordinator
CI 1-2-3-4-5-6-7-8-9-10-11-12 Vet
CI-II Burnout & Drag Champ
St. Jude Donor '03-'04-'05-'06-'07
Default Re: 3.07 to 3.54 Gains? (Beach Bum)
I'll let you know what my 2.59 to 3.45 change brings.
Old 04-30-2002, 08:34 PM
ex-gold87
ex-gold87's Avatar
Default Re: 3.07 to 3.54 Gains? (Mr Mojo)
Beach, i hate to hear that, i may wish i stayed with the 3.07. Guess i will find out this weekend when i go to the track.
Old 05-01-2002, 07:06 PM
ralph
ralph's Avatar
i like beach saw very little gain, but your car is obviously a bit different. I do however like the 3.45s drivability on the street more than the 3.07s. I think those twin turbos might like a little extra gear....let us know how you make out
[Modified by ralph, 5:07 PM 5/1/2002]
Old 05-01-2002, 07:40 PM
ex-gold87
ex-gold87's Avatar
Default Re: 3.07 to 3.54 Gains? (ralph)
I really liked the 3.07s but the car needs to be shifted into overdrive at the end of the 1/4. I was running through the lights at the other end at 5800 rpms( in drive) and its just not making power up there. I was thinking the 3.45s might let me get the car into overdrive and back into rpm range where the car will pull. Might not work but I guess its worth a try anyway.
Old 05-01-2002, 07:50 PM
mackeyred96
mackeyred96's Avatar
Location: Former NCM Drag Racing coordinator, National director Corvette Challenge Spring Hill, Tennessee: Whiting, New Jersey
Cruise-In VI Veteran
YA?????????????????? :confused:
Old 05-02-2002, 09:10 AM
93 ragtop
93 ragtop's Avatar
Out of courisioty how many of those 1.5's 60 ft times were run on that dana 36. The reason I ask, I heard that they come apart way before that.
Old 05-02-2002, 02:41 PM
ralph
ralph's Avatar
Sounds like you might have gone in the wrong direction. A 273 gear would've kept your rpms down a little more at the stripe, rather than having to shift into OD.
Old 05-02-2002, 09:33 PM
ex-gold87
ex-gold87's Avatar
Default Re: 3.07 to 3.54 Gains? (Red 86 4+3)
I would really have to go back and count time slips, i would have to say 6 or 8 sub 1.6 passes. I have to leave at a dead idle or is spins way too bad.
Old 05-02-2002, 09:35 PM
ex-gold87
ex-gold87's Avatar
Ralph, you may be right, i hope your not but i will see when i get to the track hopefully this weekend.
To 3.07 to 3.54 Gains?
Quick Reply: 3.07 to 3.54 Gains?
