Ratcheting Shifter made in the USA for C4 Corvettes
Please check out the Ratcheting Shifter that I had made for my 86 corvette. I sent him the shifter console glove box assembly and the shifter to see which one of his shifter could be made to fit into the space. I wanted one like this
http://www.youtube.com/watch?v=gr6Fq...feature=relmfu
http://www.youtube.com/watch?v=YJ7P7...feature=relmfu
But there was not enough space in the tunnel area to fit that shifter.
So he redesigned one that would work in the limited space. If there was more space he would have added another gate so it would be able to go from First to Park without ratcheting.
Here is the video
http://www.youtube.com/watch?v=FXs2P5YRh74
Here is the video
In the video of the C4 unit it looks like you have to hold the lever in reverse, is that accurate? Where is this person from and how do you get intouch with them?
http://www.kilduffmachine.com/contact/contact.htm
It stays in reverse just like the other gears, he is just showing the difference between other ratcheting shifters and his. If you check out his other videos, he has a thing about going neutral/reverse/drive and how his shifter is like a factory shifter when it comes to changing between those gears for parking/rock crawling. To his point that is a problem with all of the other ratcheting shifters.
