Hammerhead 12 Bolt Center Section
Having my Hammerhead 12 Bolt Center Section installed in my 1986 Corvette Dana 36. I got it from the Street Shop in Athens, AL . It can handle 1000 horsepower with no problem, It requires a Dana 44 Batwing. It's being done at Heisler Automotive in Hamilton, New Jersey is doing install.
Nice, looks like a serious piece......i'd like to see some pictures of it when it's installed. What are you using for a posi unit and how are the stub axles retained?
You have to call and speak to Tray, it’s not listed on the website
HammerHead 12 Bolt based Aluminum Differential Housing
C4 Corvette Flange Pattern
5.5 Wide Pattern Mount with Four 0.56 Thru Hole; 2.527” Bearing OD, 2.570” Seal OD; Bright Silver Nitro –Plated In/Out
Build HammerHead 12 Bolt Rear Differential Assembly to Include:
New Eaton 30 Spline Positraction Unit
3.73:1 Gear. Bearing kit, Seals, and Pinion Yoke
Billet Chromoly Axle Stub for 10.7W HammerHead 30 Spline Long Side to 1350 Flange
1350 U-joint Flange, 4 Bolt for 10.7 Hammerhead
Billet Pinion Spacer for C4 Torque Arm
The spacer had to be cut into 2 because it was too tall to fit in the C-beam on one side. Half on top and bottom was what is needed to center the Hammerhead for driveshaft alignment
