Drag Racing Results, Trap Speed, Reaction Time, Driving Technique, Tips for Running the Corvette in the ¼ & 1/8 mile, Events
What could cause this?
Old 10-10-2017, 10:36 PM
yedister
yedister's Avatar
Default What could cause this?
Got a call from the guy working on the Vette. He has it on the dyno, he said that after a few pulls on the dyno that the valves are getting noisy. Sounds like that they loosen up. Is that normal? I have a Jesel Shaft Rocker setup. The shaft assembly was removed back in January to change to the bushed lifters, new length pushrods were needed, went from a 6.8 to 8.6 inch, rocker arm alignment was checked. The changed was performed by a mechanic that is a serious racer. It has no run time on the motor after he adjusted the lash and drove out of the shop.
Thanks for your assistance
Old 10-16-2017, 11:21 AM
ralph
ralph's Avatar
New valvetrain taking a set under some stress? Recheck the lash and see if, in fact, it loosened up. If so, then reset lash and keep a close eye in it. If it loosens again, I'd start digging deeper.
yedister (10-24-2017)
Old 10-20-2017, 08:28 AM
4 Speed Dave
4 Speed Dave's Avatar
Changed from 6.800 to 6.800 pushrod lengths? [You types 8.6 to 6.6 but I assume you meant 6.800-6.600.] .200" is a HUGE change somebody goofed really badly on the assembly of the valvetrain. Pushrod lengths come in .050 increments I can see maybe being off .050 but .200? Good luck in tracking down your issue.
Old 10-20-2017, 01:03 PM
Frans96ss
Frans96ss's Avatar
St. Jude Donor '09
I was thinking the same thing.... Now it says 2 inch haha.... but yes .200 is HUGE in pushrods.
Old 10-24-2017, 05:23 PM
yedister
yedister's Avatar
Thanks for the response
The pushrod seat height is different.
Left one is the old one, the pushrod seat is at top of lifter. Right one pushrod seat is below link bar. should have taken a picture with the other side showing
Notice the pushrod seat, one is offset, the other is centered
The pushrod seat is inside the body of the lifter.
The height of the link bar location is the important thing.
Old 10-24-2017, 05:26 PM
yedister
yedister's Avatar
Adjusted valves and made a few more pulls, no problem from the lifter.
To What could cause this?
Quick Reply: What could cause this?
