Tire suggestion
Tire suggestion
I have an 05 cam and header car M6 with base 19/10 rear wheels. Do you guys have a suggestion of a tire I could use for a little more grip than Super Sports. Probably won't drag race the car too much so not sure if I want to buy wheels and tires just for track. The car makes 450whp. Looked at MT ET Street but not sure how good they are for street.
The new Toyo proxy r888R. 285/35/19. There a track tire and stick with no spin on my c-6 a-6 car. That's on the street and the 1/4 mile. 11.8/121.19 I have nto5R's and I felt unstable with then in corners and when they break traction it's all over. I can run higher pressures with the Proxy's as well without any spin or slide. Surprisingly I have good confidence with these.
I went 11.0s on less power with a hoosier QTP on 16" fbody wheels. Just had to grind on the upright and ball joint a little. You could make 17s clear no issue. M6 car likes a bias ply but you need to run bias fronts as well or it gets a bit sketchy lol If you go drag radial id use MT my NT05R were junk on the street...... good luck op
