how do you break in a cam?
Old Mar 24, 2006 | 10:48 PM
exline's Avatar
exline
Default how do you break in a cam?
I just installed a cam in my 350 and put on the lube for the cam and lifters then fired it up and let it run for an hour varying the rpm like my friend told me to.then changed the oil and went for a ride and when i got home it was ratteling.when i tore it down i had a lobe worn off the cam.Ithe cam i pulled out was a 520 lift cam dynamics and it worked fine but was not good with the higher gears i put in so i went with a smaller cam .474 i think and it ran real well until it tore off the lobe.
so any good advice on a cam install? how long do you let it run,what rpm?thanks
Old Mar 25, 2006 | 10:18 AM
danno85's Avatar
danno85
What I've always heard, read and done, is fast idle the engine at about 2000 rpm for 20 minutes and don't vary the rpm.
This tech bulletin from comp cams about how the lubricity of modern oils has changed, and the impact that has had on flat tappet cams, is interesting.
http://www.wildgooseperformance.com/news.html#tech
Dan
Old Mar 25, 2006 | 08:35 PM
Deakins's Avatar
Deakins
2000 RPM for 20 minutes is the way to go.
Old Mar 27, 2006 | 07:54 PM
427Hotrod's Avatar
427Hotrod
2020 C2 of the Year - Modified Winner
2020 Corvette of the Year (performance mods)
C2 of Year Winner (performance mods) 2019
2017 C2 of Year Finalist
First use the cam lube they send with it on the lobes and the lifter bottoms.
MAKE SURE that you have it timed properly so that it starts INSTANTLY. Don't want to crank on it a long time.
Make sure carb is full of fuel before you spin it over.
You DO want to vary the rpm. A cam is lubed by slash lube and you need to change the rpm occasionally to throw it to different places. One constant rpm can starve it on particular lobes.
Get some GM EOS...put a can in it with some good plain 'ole Dino oil. The diesel stuff is always a good idea. Rotella or Delo400 or some Valvoline Race Oil. I wouldn't use synthetics for this part.
I would overfill it a qt during cam break in to help throw some oil around in there.
Are you sure you had lifters adjusted right at start up? Or at least pretty close?
Good luck with new setup!!
JIM
Old Mar 27, 2006 | 11:36 PM
DragMan's Avatar
DragMan
Cruise-In VII Veteran
I agree on vary the RPMs.
Old Mar 30, 2006 | 11:30 PM
Corvette Kid's Avatar
Corvette Kid
Large Impressive Member
From: Good health is merely the slowest possible rate at which one can die
St. Jude Donor '04-'05-'06-'07
Assuming all else was well, I'd also suspect an adjustment problem. Is this a flat tappet engine? I'm guessing that it is. Even so, .520" lift is not that radical and you should not have had a problem. Still though, it's sometimes advisable to break in a new cam with lighter springs and then switch to the heavier, appropriate ones for the application.
Old Apr 1, 2006 | 05:27 AM
comp's Avatar
comp
Old Apr 2, 2006 | 02:42 PM
Gordonm's Avatar
Gordonm
I run at 2000 rpm with a slight blipping of the throttle to vary the rpm. I run double springs and always remove the inner spring for break in. I run Valvoline Racing oil for break in and from then on. Much better lubricating package. I have never had one fail on me.
Old Apr 6, 2006 | 11:02 AM
adown's Avatar
adown
I've always been told to run non-detergent for breakin. On my last engine I was told TRY to run non-detergent, if you cant find it run castrol 20wt. Is non-det. still being used for breakin or is that dead and gone?
To how do you break in a cam?
