Good book to learn about EFI?
Old Dec 13, 2001 | 05:27 PM
Flareside's Avatar
Flareside
Default Good book to learn about EFI?
I'm seriously considering selling my tripower carb setup, then moving to some type of fuel injection system. Are there any good books out there on this subject?
What's the difference between open and closed loop systems? Any specific systems I should be looking at? Engine will be 496 to 540 cube around 550 hp.
-Joe
Old Dec 13, 2001 | 06:29 PM
Monty's Avatar
Monty
Default Re: Good book to learn about EFI? (Flareside)
A closed loop system uses an O2 sensor to provide feeback to the ECM as to the A/F ratio. An open loop system does not utilize an O2 sensor and relys on the coolant temp sensor, throttle sensor, MAP sensor, etc to 'lookup' the appropriate A/F ratio. Clsoed loop systems operate in open loop during wamrup until specific parameters are met like coolant temp, etc and the exhaust temps reach apporx 600f. Heated O2 sensors are available which can reduce the amouynt of time the system operates in open loop for emissions and fuel economy reasons.
there is a pretty good boot out by Motorbooks called about efi. I can't remember the exact name, it's subtitled Installing, Modifying, tuning Electonic Fuel Injection Sytems or somehting. I have it at home, I'll post the name when I get home if no one else does. It's pretty a pretty decent book. It covers various OEM EFI systems as well as several of the popular aftermarket setups and even includes sections of forced induction applications.
If you jst need a good, easy to use EFI system the Holley 950 system seems like a good deal. They even offer a complete kit including a manifold. etc for BBC's. It's abotu $3200 I think, not bad, when you consider it's pretty complete.
Old Dec 13, 2001 | 07:56 PM
drive it's Avatar
drive it
"How to tune and modify CHEVROLET FUEL INJECTION" author is Ben Watson. It's part of the Motorbooks Power Tech series. Mine is dogeared with grease smudges-so yea it's a good one.
Old Dec 13, 2001 | 09:52 PM
Monty's Avatar
Monty
Default Re: Good book to learn about EFI? (Monty)
Besides the one listed above, another good one is "Fuel Injection Installation, Performance Tuning, Modifications - Installing and Modifying Modern Injection Systems for Ultimate Performance" by Jeff Hartman. It's a Powerpro Series book by MBI Publishing. ISBN: 0-87938-743-2.
Old Dec 14, 2001 | 12:21 AM
Flareside's Avatar
Flareside
Thanks guys. Amazon.com had both of those books. Now to find the time to read them!
-Joe
Old Dec 17, 2001 | 09:34 PM
korvetkeith's Avatar
korvetkeith
I just learned most of what I know about fuel injection in the February 2002 Chevy High Performance.
To Good book to learn about EFI?
