Watch What Happens to an Engine Running Without Oil
CorvetteForum Editor
Running your engine without oil isn't as explosive as you might imagine, but it's certainly not optimal.
Read the rest on the Corvette Forum homepage. >>
The test is almost worthless, no load was on the engine when the test was performed. Try the test again with a load and see what happens. (It will not end as well)
