jetting a holley 750 dp for a 454
Hello,
we have built a 454 for a Glastron CV23 jetboat , with LS 6 pistons # 3963550
ported peanut port heads, stock valves
a stage 2 camshaft ENGESH 1139R
CMI longtube headers, dual plane intake manifold
comp cams roller rockers
I just bought a Holley 750 Double Pumper, does anybody of you know which size jets I have to look for in this set up?
Best Regards
Ronald Jonkers
(The Netherlands)
Best Regards
Ronald Jonkers
(The Netherlands)
Which Holley 750 DP did you buy? (The List number is on the front of the choke housing.) Having the List number at will give us a start for the factory installed jets, power valves, and accelerator pump squirters. Just curious, why did you go with a double pumper instead of a vacuum secondary Holley? A vacuum secondary usually gives a better throttle response depending upon the drag induced by the hull shape and propeller design. DP's are usually best for extremely light weight boats (racers) with little drag.
