427 crate motor questions
Old 11-09-2018, 10:20 AM
micscottj
Junior Member
Default 427 crate motor questions
I just bought a 68 convertible. It was a 327 car, but has had a zz427 crate engine put in it. I want to do an update from the carb and hei ignition.
Are there any modern gm efi systems that will fit on that engine are am i relegated to aftermarket?
If anyone has an ideas on better forums for this kind of question, please let me know.
micscottj is offline
Old 11-16-2018, 09:50 AM
robert miller
CF Senior Member
robert miller's Avatar
Received 1,175 Likes on 1,069 Posts
Default ttt
Go with a after market set up on it also you can buy a new gas tank that has the elec fuel pump in it with all the lines. This way you can if you ever want put the stock parts back onto the car that look & still stock. Plus cost will be a ton cheaper on the
robert miller is offline
Old 11-16-2018, 10:40 AM
micscottj
Junior Member
I ended up going with the Edelbrock Pro-flo 4 multi-port system. i am installing this weekend.
I also bought a new tanks inc tank and fuel pump from summit. after looking at all my other fuel pump options. this was clearly the easiest and probably best way to go.
Quick Reply: 427 crate motor questions
Sponsored Ads
Vendor Directory
Contact Us - About Us - Archive - Advertising - Cookie Policy - Privacy Statement - Terms of Service
© 2019 MH Sub I, LLC dba Internet Brands
  • Ask a Question
Question Title:
Description:
