Finally getting my 93 Trans Am build going
Pro Mechanic
C5 of Year Finalist (performance mods) 2019
2017 C5 of the Year Finalist
2016 C5 of the Year Finalist
2015 C5 of the Year Finalist
I Believe In The Beer Fairy
This should give you all an idea of what's coming:
"Got Boost!?"
Nicey Nice.....
now Checkout this current storyline and the vids.
Guy is going 9's with a Non LS1 Smallblock w/ Boost thru a stock (I kid you not) 2.73 10 bolt & driving it out easy.
http://www.ls1tech.com/forums/drag-r...ar-10bolt.html
Pro Mechanic
Nicey Nice.....
No problem. I am parting out my 94. I have alot of parts including a BigStuff3 system, nexus gauges that mount in the vents of a firebird, BMR k member and alot of other stuff. Let me know if you think of anything!
Pro Mechanic
What I specifically could use would be fuel injectors if they're big enough or fuel system components as that's what I don't have done yet. Meth injection system too.
No I work in Marissa, IL. I had a black 01. Now I have a TBSS. My wife and I wanted a child so my vette had to go. I'd love to get another on but I don't see it in my near future. I also have 94 TA I drive for a work car every day. That motor looks like it will be fun to cram into that thing.
Pro Mechanic
Everything should fit in there quite nicely. The worst part is going to be finding a fan setup to squeeze in without the turbo compressor housing riding against it. The rest of the piping is pretty nicely tucked and is routed around key components really nicely. The guy that designed the kit really did a bang up job on it considering his mock up motor didn't have a 7qt Milodon pan or BMR K-Member.
Pro Mechanic
Finally got some time recently to get some stuff done. Got the K-Member and A-Arms swapped, and buttoned up the motor today (freeze plugs and cam plug) and got the street twin clutch installed on the block. Just the bellhousing and tranny and I can drop it all into the car. It's pretty much nuts and bolts from there.
Pro Mechanic
Pro Mechanic
As for the install, I thought about doing it from the bottom, but for some reason I'm just more comfy doing things through the top. Pulled and done three that way without issue, though a LOT of the success is because of that "Happy Hooker" that I've got. Angles things just right for an easy pluck and drop.
It won't be running for a little while. Waiting on my home refi to close before I order my fuel system stuff (over $1K in -AN fittings and hoses, two pumps, regulator, ect), and have a bead on a nice used Alky Control Meth kit for $300, and still have to fab cold side piping, mount the intercooler, get a couple of gauges, ect. I figure if all goes well and I can keep making progress I'll be firing it up around the end of April and PRAYING that nothing breaks because of how long the motor has been sitting.
Pro Mechanic
This was NOT a one man job for the faint of heart. My back is killing me but the end result is sooooo worth it.
