1991 Pontiac Firebird 5.0 Delco Loc II Radio Help
Hello. I have a 1991 Pontiac Firebird convertible 5.0 tbi. It is is excellent condition, with only 1 problem...The radio doesnt work! It has the Delco Loc II radio/cd player in it, its the original radio and right no it isnt functioning properly. It put out no sound and when turned "on" and when off, it only displays 0:00 for the time and if you press any volume button it just displays volume but no change. When "set" is pressed it says set but nothing happens. The antenna, which is electric, doesnt go up when its "on". It will take a cd and eject it but like i said nothing plays. No buttons except set, volume, and power do anything, if that. The fuses are all good and It used to run fine, so im at a loss. I know about the lock mode it goes into if you disconnect the battery or anything like that, but it isnt locked. I was thinking there may be a problem behind the radio, like an internal or rearward fuse that needs to be replaced or a loose connection but i havent checked that. Any ideas are appreciated!
Will
Will
I actually have no answers for you but it sounds like the radio is shot. I actually put in a cd player from my 99 Grand Prix in my Trans Am. Do you know if yours is factory? I know most of them from that year still had cassette
Will
Just an update- I sent the radio to a place in pennsylvania where GM would have originally sent their radios for repair, and they said the radio had a known problem and needed very expensive parts to fix. They sent me a fully refurbished unit and it works great! The radio really sounds good.
Will
Will
