2002 CETA trans am for sale
The ultimate street/strip cruiser.=left
I built this car to sacrifice nothing on the street or strip. Every part on the car was bought brand new.=left
Everything on this car works as it did from the factory, Air conditioning, windows, lights, antenna. etc etc!!=left
=left
2002 Trans am CETA WS6=left
101,500 miles.. I purchased the car from Orlando Florida 2 years ago and drove it directly off the car carrier to Tune Time Performance in Lakewood NJ The car was 100pct stock 2 owner vehicle that had never seen salt or snow.=left
=left
Everything has been modified with brand new parts- I have receipt's for everything except the Weld skinnies for the front.=left
Decals are MINT=left
Interior is in very good shape 8.5/10 No dash cracks, no door panel cracks-- minor wear on seat lumbar=left
exterior is in good shape as well, Car is ceramic coated. tiny crack on the edge of the drivers door. Other then that its very good.=left
Air conditioning is ICE COLD!!=left
=left
Rebuilt 346=left
MAHLE Pistons=left
Comp cam- custom grind=left
trick flow 215cc heads=left
ARP hardware=left
manly rods=left
LS7 lifters=left
double timing chain ETC ETC- I have receipts for everything=left
LSX 102MM manifold with 95MM edelbrock TB=left
=left
Trans- Brand NEW RPM level 7 40L60E=left
vig 3600=left
3.5 alum driveshaft=left
trans cooler=left
HD trans pan=left
=left
Rear- Strange 12 bolt=left
3.73 gears=left
HD posi unit=left
Powder coated black=left
=left
Suspension=left
BMR Torque arm=left
BMR adj LCA's=left
BMR- Sub frame connectors=left
BMR- ADJ panhard bar=left
QA1- Fully adjustable shocks on 4 corners=left
=left
Nitrous- ZEX 100 SHOT=left
Dyno time only=left
3 bottles- 2.5 of them are full Sprayed it on the dyno to tune only=left
electric bottle opener=left
Nitrous outlet ASH tray switch=left
purge=left
bottle warmer=left
Custom Spare tire bottle mount--- will fit the 10lb or 15lb bottle=left
lingenfelter Window switch-- w/ timing retard=left
nitrous outlet standalone fuel tank under hood=left
=left
Wheels- 4 Mint factory CETA wheels Front's with brand new street tires=left
Rear with Brand new mickey Thompson S/S street radial=left
Weld RTS skinnies for the front=left
Weld RTS 15x10 for the rear with ET street R tires-- 1 track pass (blew the stock trans, hence the brand new RPM level 7)=left
=left
MISC-=left
LED fog lights=left
stainless brake lines=left
Blue tooth adapter=left
all speakers replaced=left
tints-- some scratches on them- must be from original owner=left
ceramic coating=left
SLP car cover=left
Fresh oil change=left
The tune is dead on and idles perfect on a 85* day with the air on.=left
I have $40,000 in receipts=left
I am sure I'm forgetting some parts and details. I have the stack of receipts to back up all work and modifications.=left
=left
Reason for selling=left
I DO NOT HAVE TIME TO USE THE CAR... 1000 Miles and 1 track pass in the 2 years I have owned it.=left
Please no low ball offers I do not need to sell the car. I am just tired of seeing it sit in the garage.=left
NO TRADES NO PART OUTS!!
=left
=left
=left
Rebuilt 346=left
MAHLE Pistons=left
ARP hardware=left
manly rods=left
LS7 lifters=left
=left
vig 3600=left
trans cooler=left
HD trans pan=left
=left
3.73 gears=left
HD posi unit=left
=left
Suspension=left
BMR Torque arm=left
BMR adj LCA's=left
=left
Dyno time only=left
purge=left
bottle warmer=left
=left
=left
MISC-=left
LED fog lights=left
SLP car cover=left
=left
Received 1,679 Likes
I only see 3 pics... Looks nice though.
