Factory Correct Resto Corvette Restoration Tips, Bodywork, Numbers Matching, Period-Correct Modifications or Original Condition
1969 842 heads
Old 03-29-2013, 05:06 PM
JASPER63
Cruising
JASPER63's Avatar
Default 1969 842 heads
The first number on the head casting is hand stamped (3).
The head is 3919842.
The hand stamped 3 appears on a slight curvature on the head casting.
Is this legit?
Cheers.
Old 03-30-2013, 09:33 AM
Easy Mike
Support Corvetteforum!
Easy Mike's Avatar
Received 1,469 Likes on 1,248 Posts
Cruise-In II Veteran
Possibly. Similar examples have shown up.
Old 03-30-2013, 11:11 AM
JASPER63
Cruising
JASPER63's Avatar
Thank you for your response.
These heads have 20,000 org. miles on them and have been stored.
Are these heads being replicated?
Thanks again,
Cheers.
Old 05-20-2013, 10:44 PM
rickyfco
2nd Gear
rickyfco's Avatar
hello, im rickyfco..im new here...I found out today my old big block chevy 461 has 3946074 cast heads , pulled intake and found code date 10.1.69...virgin heads..stored for last two years in garage ..wondering if they are worth anything..thanks ricky
To 1969 842 heads
Quick Reply: 1969 842 heads
