Need fuse help
Need fuse help
I noticed tonight that the electrochromatic mirrors, the vanity lights in the visors, the "map" lights on the rear view mirror and the light in the glove box on my 03 vert are not working. Simple right? FIND the right fuse! The owner's manual does not specify any of the above items nor does the sticker on the inside of the cover of fuse/relay box under the hood. (add to that the fuse diagram in the owner's manual is different than the one on the sticker on the box cover)
Can anyone tell me which fuse is it? Thanks in advance.
Here is a diagram It's labeled as "Monitored (Inadvertent) Load Control ":
1 Post
CI 2-3-4-5-6-7-8-9-10-11-12 Vet
St. Jude Donor '06
Hey Jim,
I think I saw you on your Scooter on RT 64 yesterdeay (Sat) enjoying a great day for Riding. Good luck getting your fuse fixed.
You probably did. I made a run out to Oregon, turned around and came back. I was supposed to head up to Mineral Point, Wi. but my rididng buddy had a car accident (hit a pedestrian) Fri night so I was solo. Rick was right on with the fuse. Replaced it but it blew again. I think it may be the vanity lights in the visors as they get flexed all the time when dealing with the top (up or down).
Good Luck to you with your upcoming move.
Jim
Hey guys,
I have Zr1 2009, yesterday had an issue with cooling fan suddenly did not work well and the temperature became high so I turned off the engine and turned it on again and it worked well? I think from the fuse, but where can I find the fuse and what is the number of if and what Amp need?
