Indianapolis Engine Builders
I am looking for an engine builder. I have finally moved my 1971 Corvette to my new house and space is tight. I have the stock block and heads which I want to have redone to stock 1971 L48 specs. It is only a 2 bolt.
Then I have the motor that my dad replaced the stock one with (he blew the stock motor racing). It is also a 350, .030 over built to 1970 LT1 specs. That motor was running high compression and several other things, blue printed etc. It was a pain and not very street friendly setup. I am considering going to a 383 stroker with it and making it something with good power but still usable.
Anyone have information, good or bad, on engine builders in the area?
just dropped my car off to be tuned @norris motorsports, he has plenty of work on ls engines going on.
MIKE DUKE is another option
he has helped me in the past and does top notch work
pm me if you want his info
