No pictures, No more!!!
I no longer receive pictures posted on the forum. I use Win XP and FireFox. I checked the options and all is normal. Any help would be appreciated.
Thanks, Curt
Thanks, Curt
CI 3-4-5-6-7-8 Veteran
St. Jude '03-'04-'05-'06-'07-'08-'09-'10-'11-'12-'13-'14-'15-'16-'17-'18-'19-'20-'21-'22-'23-'24
Thanks, Curt
Thanks, Curt
Try clearing all the cache in Firefox. Log out of the forum and back in to clear all the forum cookies.
If that doesn't work, try IE and see if you have the same problem.
Thanks for the come back. I tried the log off, cnx the pop up blocker and the catch, no help. I'll reboot and try IE. I'll report back tomorrow.
Thanks again for your help, Curt
Originally Posted by Techies
1 - We recommend using IE or Firefox.
2 - Make sure you are using most current versions of IE or Firefox. If you have IE for example - run the windows update and install updates.
3 - Check Personal Preferences in Corvette Forum to ensure that images have not been turned OFF.
4 - Disable/Remove all Pop Up blocker software/apps.
5 - Logout out completely from Corvette Forum.
6 - In I.E. go to “tools” -> “internet options” -> under the section temporary internet files click “delete files”.
In FireFox go to “tools” -> “options” -> “privacy” tab -> “cache” -> “clear cache now”.
Once this is done, close all browser windows, reopen them, and try performing the action that they were unable to do beforehand.
7 - If that does not solve the issue, go back to internet options, delete the cookies, close the browser window, reopen in and try again.
8 - If the same issue appears try another computer.
IE works
Originally Posted by 98Pace00Jeep
Try some of these tips if you haven't already.
Curt, copy this link
http://forums.corvetteforum.com/zeromain
close your browser, open up the browser again,
copy the link into the address bar, and hit enter.
(in other words skip the main page www.corvetteforum.com,
and go straight to http://forums.corvetteforum.com/zeromain)
LT, thanks for the suggestion. It didn't work on FireFox. What I get or don't get is the Photographs that are posted with the message field.
Thanks for the thought, Curt
