Pop up ads from Vdopia
#44
I know what you mean!!! It is almost totally unusable with the Bounty pop ups and the like. Curl at the corners etc. I just found out that it really helps tremendously if you go into settings on your iphone, then go to Safari, and at the bottom, hit clear cookies. This gets rid of a lot of the pop ups. You will have to sign in again with your user name and password but it helps. They still come, but much less frequently. Good luck as the pop ups make it pretty much unusable. Hope it helps.
