64 Corvette turn signal issues
PROBLEM: Rear turn signals not working.
The rear parking lights are working.
PART REPLACE: Turn signal switch, Flasher, Brake light switch, light bulbs.
TROUBLESHOOTING:
All rear light housings removed, cleaned contacts and sanded and electrical contact cleaner used.
At the turn signal switch checked for power at rear left and right turn signals wires, used power check light. Power coming out of both wires. Good.
At the body harness connector for the rear under the drivers kick panel, checked the 2 rear turn signal wires and there no power?
TROUBLESHOOTING:
Instead, please find the correct section, based on the generation of the Corvette.
Go back to the main forum page:
https://www.corvetteforum.com/forums/
Now start to slowly scroll down until you see your generation of Corvette listed.
C1 or C2 (1953 - 1967)?:
https://www.corvetteforum.com/forums...2-corvettes-4/
We encourage new members to take some time to browse around the site and read the Announcements and Stickies as they contain important and frequently asked information.
Thank-you
