Recessed headlights on c-3
When I bought my 75 it had the recessed headlight kit installed. I would like to convert back to pop-up, but don't want to spend the $$$ now. Plus if I ever get the motor in I want I may not have the vacuume to run them. I am thinking of trying electric motors & possible conversion from another type of car, have any of your tried anything yet??
Thanks, Stodd
Thanks, Stodd
Cruise-In VI, VII & XII Veteran
St Jude Donor '07-'08-'09
Welcome aboard. Sorry I cannot answer your question but, if you post in the C3 Section below I bet someone will help you out.
Aloha Stodd welcome to the CF on your question you need to post that up in the C3 section where the C3 members hang out. Best of luck on your plans, as far as vacuum, you could run a vacuum canister, which I did in the past when running a big cam.
