New Corvette owner
Old Nov 8, 2014 | 12:43 PM
Jeffs y2kfrc's Avatar
Jeffs y2kfrc
3rd Gear
Default New Corvette owner
Hello fellow vetters, after a long search for the car with everything I wanted, I finally found it. It's a 2000 frc, the only thing I don't care for is the fact that someone put Z06 rear brake ducts on it. Not that I don't like them I just don't want it to be a "fake" anyways thanks for accepting me to the forum. Jeff in upstate NY
Old Nov 9, 2014 | 12:14 AM
JW3101's Avatar
JW3101
St. Jude Donor '11-'12-'13-'14-'15-'16-‘17-‘18
Jeff, welcome to the forum and congrats on the FRC!
Old Nov 9, 2014 | 12:20 AM
2010BlueGS's Avatar
2010BlueGS
Welcome to the forum from So Cal !!!
Old Nov 9, 2014 | 10:50 AM
gilhuly's Avatar
gilhuly
welcome aboard Jeff!
Old Nov 11, 2014 | 12:48 AM
Brandons72vette's Avatar
Brandons72vette
Welcome!
Old Nov 14, 2014 | 11:28 AM
Jeffs y2kfrc
3rd Gear
Thanks, I have a few mods to do over the winter months,mostly engine mods. I also have a bad gear in a headlight motor. Do you guys suggest switching to brass gears or just picking up a new motor assy.
Old Nov 14, 2014 | 01:07 PM
old stingray's Avatar
old stingray
Welcome to the forum.
Old Sep 25, 2015 | 03:50 PM
Mr Russ's Avatar
Mr Russ
The brass gears are best/least expensive long term fix. ~$35
For the short term disconnect the lift mechanism link from the motor/gear shaft, rotate the motor by hand 180 degrees (from the other end of the motor, there's a ****) and reconnect the lift link. The mechanism inside the motor/gear only uses half the plastic gear inside. This allows it to use the unused half to raise and lower the headlights.
Remember to disconnect the motor power while doing this.
Here's a write up with lots of pics to install brass gears (good info for the short term fix also):
https://www.corvetteforum.com/forums...orialized.html
Good luck
Old Sep 28, 2015 | 07:38 AM
jehuds10's Avatar
jehuds10
Welcome to the forum Jeff!
Old Sep 28, 2015 | 09:25 AM
wkidvette's Avatar
wkidvette
Welcome to the forum!!
To New Corvette owner
