Valve lifters
Old Oct 22, 2016 | 12:25 PM
Dirk1's Avatar
Dirk1
Cruising
Default Valve lifters
Hi all,
I have a car with a 327 engine from 964.
engine has been standing for about 20 years,looks like been partly reconditioned but would not start.
Tried for several hours untill I decided to releive all the valve lash adjusters.Runs now with of course rattling rockers.Normally these engines were equipped with hydraulic lifters so I came to the conclusion thet either solid lifters were used or the hydraulic ones were wrongly adjusted(too much tension).
I am a European so not really used to hydraulic lifters. Is there a way of finding out without takjing the inlet manifold off? I measured the distance of a rocker that is put under tension but after a few hours the distance stayed the same. Do the hydraulic lifters go off after say one night? Or is there another simple method to find out what sort is put in?
Thks,
Dirk,Antwerp,Belgium,car is Gordon Keeble
Old Oct 22, 2016 | 12:56 PM
FX VETTE's Avatar
FX VETTE
Welcome to the CF! Your question can probably be answered quicker if you post it in the C1 & C2 section.
Old Oct 22, 2016 | 04:04 PM
Vette_DD's Avatar
Vette_DD
Here's a link to the C1/C2 forum:
https://www.corvetteforum.com/forums...2-corvettes-4/
Make a new post there and they will be glad to help you.
Old Oct 22, 2016 | 04:05 PM
Old Ben's Avatar
Old Ben
2017 C6 of Year Finalist
Welcome to the forum.
Old Oct 22, 2016 | 04:09 PM
rkj427's Avatar
rkj427
Pro Mechanic
Welcome to the forum!
Perhaps after sitting for so long, the hydraulic lifters collapsed, and led the original owner to adjust improperly?
Once the engine is running, they will fill up with oil, and should hold it internally without collapsing. Then you can properly adjust valve train lash.
Old Oct 22, 2016 | 09:13 PM
jehuds10's Avatar
jehuds10
Old Oct 23, 2016 | 04:03 AM
Dirk1's Avatar
Dirk1
Cruising
Thks guys!
Old Oct 23, 2016 | 09:17 AM
guappy's Avatar
guappy
Welcome
Old Oct 23, 2016 | 09:33 AM
gilhuly's Avatar
gilhuly
good luck and welcome to the forum!
To Valve lifters
