77 does nothing when turning key. No lights no power
when I turn my key on my 77 I get nothing (no dash lights. No power anywhere). I connected the starter terminals with a screw driver and with the key in the on position and the started turned and also gave me power back in the car. It started right up after that. I drove it around, turning it off and starting it back up about four times and it seemed fine. I let it sit for about and hour or two and it did the same thing, no start, no dash lights, no power anywhere. I tried to engage the starter with a screw driver again and it engaged but it’s not giving me power back or letting me start the car. Any ideas?
Pro Mechanic
Received 3,952 Likes
Welcome to the forum!
This is the introductory area, you would have more opportunity for responses in the C3 General / Tech Areas. Links below.
https://www.corvetteforum.com/forums/c3-general-119/
https://www.corvetteforum.com/forums...performance-3/
Received 19,288 Likes
'20-'21-'22-'23-'24
This is already posted in C3 Tech.
