I wanna be like you guys!
Hello,
I'm obviously new here. I am looking soon to invest in an older Corvette, possibly one that's 1990 or slightly older. One reason for the older model is I like the older simpler look. My future Vette will be a "Sunday and holiday driver" for most trips less than 100 miles round trip. I want an automatic that's in good running condition and only needs some elbow grease and a little luv to make it even better. Not looking for a 100% restored show car, looking to spend $11,000 or less. Any of you have a 1985 to 1990 and have beginner advice for me; what to look for and what to stay away from? All good advice appreciated. Thanks!
Welcome to the Corvette Forum RetroGuy. I don't have much experience with the 79-82 C-3s, but I do know you are in the right place for expert advice. Be sure to check out the C-3 section.
St. Jude Donor '17-‘18-'19-'20-'21-'22-'23-'24
Welcome to the forum, Retroguy!
You may want to post your question in the C3 section of the forum at https://www.corvetteforum.com/forums...s-1968-1982-5/; and C4 section at https://www.corvetteforum.com/forums...-1984-1996-19/. There is also a cars for sale section in each of these that may have the Corvette perfect for you.
If you end up considering an early C4 for sale, I'd suggest looking for a late 1986, or an 87-88.
Updates for these years include:
1986. VATS anti-theft system; Anti-lock brakes; Aluminum heads (in late ’86 – reduced car weight by 125 pounds, and added 5HP to the earlier engines.
1987. Hydraulic Roller lifters added (increase of 10HP and 15lb/ft torque); rocker arm covers with raised rails to strengthen cover and eliminate oil leaks there; added thicker core radiator, and also went to two cooling fans; finned power-steering cooler added.
1988. Revised heads and new profile cam added 5HP; less restrictive exhaust if the 3.07 axle was ordered; 17x9.5 wheels with 275/40-17 Z rated tires included with Z51/Z52 suspension packages (16” wheels also went to Z rated tires); Zero Scrub Radius front suspension geometry.
Best wishes with your search.
Received 19,293 Likes
'20-'21-'22-'23-'24
Welcome to the forum. Be sure to check the for sale sections of the C4 and C3 cars as well as visit the Tech and General sections.
Pro Mechanic
Received 3,952 Likes
Welcome to the forum!
Good luck in your search!
Other's have posted great advice to help you in your search!
Received 1,679 Likes
Welcome to the CF!
2018 C4 of Year Finalist
2015 C4 of the Year Finalist
St. Jude Donor '16
Welcome and good luck in your hunt.
Platinum Supporting Dealership
Welcome to the forum, and good luck with the hunt.
__________________
Tom Wooten
National Corvette Museum Ambassador
Corvette Sales Manager
Ross Downing Chevrolet
Louisiana's #1 Corvette Dealer since 1992
985-345-1285
"PUTTING DREAMS IN DRIVEWAYS ACROSS AMERICA"
Join our Facebook Corvette community!
New Corvettes For Sale | Used Corvettes For Sale | About Us | Contact Us
Tom Wooten
985-345-1285
