74 fuel guage not working
The fuel sending unit has 23 ohms and moves when I manually lift the float. Wires, ground and tan connect to the fuel guage. 12 volts at the guage cluster. When I manually move the guage needle on the cluster and turn on the key, it will go from empty to full over hard on the needle stop. So all the parts work. Why doesn’t the guage read correctly?
Pro Mechanic
Received 3,938 Likes
This is the "Introductory Area" of the forum.
Post your question in the C3 Technical Area...…….. link below.
https://www.corvetteforum.com/forums...performance-3/
Welcome to the forum!
St. Jude Donor '17-‘18-'19-'20-'21-'22-'23-'24
Good advice from rkj427!
Received 19,234 Likes
'20-'21-'22-'23-'24
This has already been posted in multiple C3 sections.
