Bob,
I purchased the pod that has the memory buttons to replace the unit in the drivers side door w/o the memory. However the memory buttons don't work. Is there something else that needs to go along with the pod in the door. Do I need to upgrade the Seat Control Module?
Michael
P.S. I have a 99 coupe.
My guess would be that it's because if you didn't originally purchase the memory option, it wouldn't be enabled in your car's computer. There are tools out there that can change the options in your computer -- you might want to try asking on the C5 test & tune section.
