leaking differential
Old Aug 8, 2004 | 11:44 AM
b_pappy's Avatar
b_pappy
From: the GOCC are everywhere, even back from "band camp"
Default leaking differential
I know this has been discussed, but seem to be coming up empty...My (cars) rear end differential appears to be leaking, a 2000 convertible. I'm ready to take her in for the column lock fix and would like this fixed at the same time. I'm pretty sure Rydell will know all the info, but want to be sure.
Is this the TSB number (Bulletin 03042006) to get the latest seal for the differential, or can somebody show me the correct TSB number or seal P/N I want.
Thanks,
Bruce
Old Aug 10, 2004 | 05:36 PM
CorvettePartsBob's Avatar
CorvettePartsBob
This is Bob at Fichtner Chevrolet,
The latest bulletin you want is 03-04-20-005 and here is a copy of it. Good luck!!
Info - Release of New Rear Axle Seals #03-04-20-005 - (Sep 12, 2003)
1997-2004 Chevrolet Corvette
This bulletin is being issued to inform dealers that new and improved rear seals have been released for service for the above listed vehicles.
Use the new output shaft oil seal, P/N 88996703, and the new differential side cover O-ring, P/N 89047953, when repairing rear axle leaks.
Parts Information
Part Number
Description
88996703
Seal, Output Shaft Oil
89047953
O-ring, Differential Side Cover
Parts are currently available from GMSPO.
GM bulletins are intended for use by professional technicians, NOT a "do-it-yourselfer". They are written to inform these technicians of conditions that may occur on some vehicles, or to provide information that could assist in the proper service of a vehicle. Properly trained technicians have the equipment, tools, safety instructions, and know-how to do a job properly and safely. If a condition is described, DO NOT assume that the bulletin applies to your vehicle, or that your vehicle will have that condition. See your GM dealer for information on whether your vehicle may benefit from the information.
WE SUPPORT VOLUNTARY TECHNICIAN CERTIFICATION
© Copyright General Motors Corporation. All Rights Reserved.
Bob
Old Aug 10, 2004 | 09:27 PM
b_pappy's Avatar
b_pappy
Thank you so much That's what I was looking for.
Bruce
To leaking differential
