Connecticut Emissions ??
Cruising is the passion!
St. Jude Donor '07-'08-'09-'10-'11-'12-'13-'14-'15-'16-'17-'18-'19-'20-'21-'22-'23-'24
Anyone know anything about the new Connectiuct emissions inspections?
I'm thinking about getting TPIS headers for my 1989 L98 and eliminating the pre-cats but will it pass with the headers?
I have pre-cats with a gutted main-cat now and passed the old inspection without problem. With headers I guess I'll have replace the gutted main-cat with a new cat?
Hello, I am a Ct state emissions inspector. All we do is look under the car to make sure there is a cat on the car. If so we test the gas cap and then run your car on the dyno with a sniffer in the tailpipe.
Thanks Bozzman3 ! That sounds like the same procedure as the old test so I guess if you have a catalatic converter and are running clean you should be OK?
Supporting Tuner
Originally Posted by bozzman3
Thats correct ,a s long as there is a cat and your cars emissions fall below the limit you are ok. Now 1996 cars and above get a OBD2 test
I have a 01 C5
EG
You must have a cat installed. Your computer system must not be sending any codes out and your computer can not be recently cleared. The emissions machine will not give you a pass report if there is no history stored in the computer. Also your check engine light must come on when the car is first started.
Supporting Tuner
Thanks in advance
EG
You wont run afoul but your test will be aborted.Ecms have a set of memory banks called readness mointers. Each readness mointer mointers a different circuit,such as 02, evap system, etc.If you have to many of these open then your test will be aborted. Usually a week of normal driving sets enough to go thru the test.I run the Firestone in Enfield 860-741-6550 ask for Scott
Hey Scott.
Looks like I may be over to see you this spring.
Just wondering what you think, 235,235 112 LSA cam, LG pro long tubes, Random thech high flow cats.
Could I have a problem with this set-up?
Dave
Dave
Scott,
Thanks for the reply. I am working as project manager on a job in Houston TX and getting a little nervous about coming home to an awkward problem with CT emissions. When I bought this car it had no cats on it at all so I installed Random Technologies high flow cats trying to do the right thing.
Thanks for the info.
Dave
Dave
Cruise-In VII Veteran
Originally Posted by HRDTOPC54FUN
Scott,
Dave
Dave
