Garage floor - epoxy or tile?
#101
I went with the circle trac pattern racedeck, my floor was in very poor shape being 70 years old, my Garage was never finished previously so I'm in the middle of trying to finish it..don't mind the crappy pics but it's a work in progress.
#102
I have an oversized two-car garage under our new-to-us bilevel (another word for UGLY-style) home that was built in the '60s. The concrete floor was original to the house and had some staining but luckily no cracks. I had tried coating/painting a garage floor about 15 years ago, and, although today's products are probably much better, I didn't want to go through all that work again. So I checked out RaceDeck, plastic tiles at Home Depot and Lowes, and then saw them online at Costco. They are solid plastic/vinyl material that does not allow grit and dirt to go through them to the concrete below. I waited for their sale price--a few times a year they drop the price on these, and shipping is always free to your home--and bought them. They may not be as "good" quality as RaceDeck, but I think they're terrific. Easy to put down, fairly easy to cut (I used a jigsaw for trimming), and they are holding up great. I sweep the floor about once a week, and just damp mop it whenever the "OCD urge" hits me--but at least once a month.
About the only negative I've found with these tiles is only one style/pattern is offered; and only three colors: black, silver/gray and white. They also come in combos of silver/gray and black or white and black. They also sell completer kits with tapered edge tiles for the garage entrance. I think they're just more bang for the buck for the budget.
#103
They are actually made by Racedeck for Costco the difference is mostly in the warranty and the diamond pattern is different, the normal Racedeck tiles have a 15 year warranty these tiles have 10 years. They will even connect with each other except the Costco tiles are just slightly thinner. I actually do sell these cheaper than Costco and in any color the same as the regular Racedeck tiles.
#104
I had a pro epoxy job done 8 yrs ago and it is awesome, looks new, holds up to everything except welding slag. and is way better than the tiles, I did tiles in my basement and they are not even close
#105
I used epoxy in mine. My garage see's a lot of traffic...get a lift, you'll gain tons of friends hahaha. The floor had held up pretty well, save for dropping some really heavy stuff that chipped the concrete itself. If I were to change one thing, I'd go with a medium grey color instead of the blue that we went with. The blue definitely shows scratches.
If you plan to actually do real garage work in there and not just park your pretty car on it, I'd stay away from tiles....just my .02.
- Travis
- Travis
#106
The tiles are made of polypropylene and very tough. I'm pretty sure the tiles from costco are the MotoFloor Modular Garage Flooring Tiles?
I've been happy with mine. Like I noted in my post, my only complaint is when I use a floor-jack or jack stands; the weight of the car pushes the floor-jack wheels or jack stand legs into the tile causing minor damage to the tile. The fix is to use 1/2" plywood to distribute the weight across several tiles.
#107
I'm curious why you would say "If you plan to actually do real garage work in there and not just park your pretty car on it, I'd stay away from tiles....just my .02." I have a 4 post car lift sitting on top of my tiles for years now with my corvette sitting on it. No damage to the tiles at all. The Army Corps of Engineers parks their dump trucks on these. The are rated for 250 pounds per square inch with a support rolling loads of over 50,000 pounds. Short of taking a blow torch or dropping heavy pointy objects it's nearly impossible to damage these.
#108
#109
Race Deck installed this month.
#111
- Travis
