★In NY & you want a Blockit Sound Deadening Mat? COME & PICK IT UP! Save big on S&H!
Premium Supporting Vendor
Location: ★ Performance Parts & Accessories ★ 1800 778 9898
St. Jude Donor '07-'08-'11-'12-'13-'14-'15-'16-'17
Hey gang,
If you have 60 seconds and your looking to reduce interior noise, then the Blockit Sound Deadening System is for you!
Just drop it in! The Pre cut cargo mat fits perfect and lays right over your factory carpet.
Its shipped in a large box which costs approx. $30 and up. In a few days , feel free to pick it up.
We have a new storage facility 401 Columbus Ave West Babylon NY
Call first as I might not always be there or to make sure we have your mat for your gen in stock.
Available for the C5 Coupe, C6, GS, Z06 & ZR1 Coupe. C7 & Z06 Coupe & convertible.
• Quiet down your Corvette interior in SECONDS!
• Pre - Cut & lays right over your factory carpet!
• 4 Infused Layers of REAL acoustical soundproofing materials
• Great for exhaust, tire /road noise and long trips
• UV protected top layer is durable & looks great
• Feel free to lay an aftermarket carpet on top!
• 3 Piece system!
• Helps keep your cargo or trunk area cooler!
• No Adhesive. All pieces are removable & reusable!
• All raw materials are from the USA!
• Made in the USA!
• Manufactured under strict ISO 9001 regulations
Reduce interior noise in SECONDS by simply dropping in the pre cut BLOCKIT sound deadening mats right over your existing carpet!
This is NOT a thin one layer mat.
The BLOCKIT is a unique 4 infused layer combination of real acoustical soundproofing which measures 1" thick!
It absorbs and suppresses unpleasant sounds that leak into your C7s cabin.
It’s perfect for taking that annoying edge off tire / road noise & some aftermarket exhausts.
NO need to rip out your carpet & interior! The precision pre cut BLOCKIT Sound Deadening System lays right over your carpet!
Fits C7 & Z06. One large piece fits perfect in your cargo area. One piece goes behind each seat.
For the Coupe, rather then large sections removed, we have small precise cut outs for the cargo hoops.
These maximizes the amount of sound deadening material for noise reduction.
The durable UV protected top layer looks great and allows you to still use your cargo area. Feel free to place an aftermarket cargo mat on top!
Here are some posts
Having had Blockit in my Z06 - I thought it did a great job reducing noise so I added it to the C7 - Z51.
It arrived packaged well. Easy install with a precise fit. I was able to use the rings and shade. I found it able to make a nice noise reduction on all surfaces around Little Rock including interstate and different road surfaces including concrete and asphalt.
I'm very happy with the product!
Installed on my C7 Z06. TRANSFORMATIONAL! The reduction in tire noise is astonishing. Being an engineer I had planned to use my laboratory dB meter to measure noise levels with and without the TKO Blockit kit. As it turns out there is no need to do so because the noise reduction is truly dramatic. This kit is a "must have" for all but deaf C7 owners. I had a '14 Z51 which had hellacious tire noise. I was exhausted after driving it for 3-4 hours. The '15 Z06 was significantly quieter and rides more smoothly....think Chevy vehicle engineers softened the suspension bushings. Seems to be well known that the '15 is a quieter car. Just can't believe how such a relatively inexpensive and easily installed kit can be so effective. I could now drive the car across country....yes, it's that good.
Well, I had a chance to test drive my car on some roads that previously had some serious tire noise due to the road conditions. For the ease of installation and simpleness of the product; I'm very pleased with the it. I was able to lower my radio volume from where it used to be, and hold conversations without raising my voice. In fact I am now aware of other noises that I hadn't previously heard.
So bottom line: I'd recommend(your hearing my vary) .
I can't say it's equal to the kits that require full interior dis-assembly since I didn't do that, but I definitely feel there is value in the product. If you are in Southern Calif and want to try in your car, come by and we'll throw it in and you can hear for yourself. Or just take my car for a test drive.
Tom
Tom
Received my set of sound deadeners yesterday and promptly installed them in about 10 minutes.
Started the car in my garage and could hardly hear the exhaust with the windows up. Backed it outside ( a lot of snow here now ) and tried the same thing, windows down ,windows up. I will not get to take the Z06 out until spring, but I can tell you that there is a substantial difference in the noise factor just sitting in the car and listening to it run.
Great product. Can't wait to do a more extensive test in the spring, but initially this seems to be a great product !!
Many thanks,
Dave
Many thanks,
Dave
A huge hit when it was released for the C6!
Below is a list of some threads from many satisfied customers/forum members.
Within theses threads you will find a ton of others posting their positive results with the Blockit too.
http://forums.corvetteforum.com/c6-c...ation-mat.html
http://forums.corvetteforum.com/c6-c...e-product.html
http://forums.corvetteforum.com/c6-c...ning-mats.html
http://forums.corvetteforum.com/c6-c...d-deadner.html
http://forums.corvetteforum.com/c6-c...irst-ride.html
http://forums.corvetteforum.com/c6-c...rformance.html
http://forums.corvetteforum.com/c6-c...post1573973170
http://forums.corvetteforum.com/c6-c...-block-it.html
To read more about our sound deadening & damping solutions click here: http://store.tkoperformance.com/audio-security.html
Call us before coming down to make we are there & to make sure we have your Mat for your Gen in stock!
__________________
Serving The Corvette Forum For 21 Years!!
Allow us to add you to the list of extremely satisfied customers.
Order Securely Online 24/7: http://tkoperformance.com/index.html
Feel Free To Contact Us By Phone: 1800 -778- 9898 Monday- Friday 9:00am to 4:30pm
Click Here: http://www.facebook.com/pages/TKO-Pe...e/367433626633
