Progress....
POSSE ZR-1 Driver
Progress....
Dropped the new engine in today.
Was making good progress until one of the caps dropped off a U-joint and I lost one needle bearing.....
Off to the parts store in the morning.
POSSE ZR-1 Driver
Got under the car all buttoned up today, stock exhaust for now until I get all the bugs worked out. Motor mounts and trans mount tightened up, starter wired up, driveshaft, clutch mechanism, etc..... Heater hoses hooked up, plug wires run, battery in.
More to do, but progress just the same.
Cruising is the passion!
St. Jude Donor '07-'08-'09-'10-'11-'12-'13-'14-'15-'16-'17-'18-'19-'20-'21-'22-'23-'24
St. Jude Donor '10-'11-'12-'13-'14-'15-'16-'17-'18-'19-'20-'21-'22-'23-'24
Paul- to be a bad influence, how about making a dual-mode exhaust, stock rear exit for quiet driving, then electric diverters to the side-pipes unmuffled? I've been looking at my 72 with this idea if I put the big motor in it.
POSSE ZR-1 Driver
That's already the plan once I'm satisfied everything is running well. Much easier to hear what's going on with the engine with the quiet exhaust.
POSSE ZR-1 Driver
After a false start yesterday due to a dead starter, it fired up as soon as I turned the key.
Just have to button a few things up....
POSSE ZR-1 Driver
First start video....
