corbeau seat brackets bah
wow put in my corbeau seat today what a pain the brackets are so hard to get in . the seats rests on the plastic of the seatbelt roller assembly . even if i pulled the assembly the plastic cover would sill be all distorted .
I just wanna go harness's just afraid of getting pulled over.
Are your brackets bent or something? I installed my Corbeau's from TPS in under 20 mins. Also remember that the "passenger seat" goes on the drivers side and vice versa if you are installing A4's. All I had to modify was the seat belt plastics a little bit and I ground off the nub on the seat belt as well so it swivels more.
Also to make adjusting the seat easier, I drilled a hole in the seat lever and put a string threw it which makes it much easier to pull and adjust.
so went to go drive my car around the block today and noticed my seat belt is on the wrong side [ my damn fault for installing it at night ] when i ordered just the drivers seat and bracket they sent me drivers seat and bracket bah corvette specialist o well out it comes and gets cut and welded
