Off Topic Off Topic | Non-Corvette
AK47 guys I need some help
Old 03-17-2015, 12:35 AM
tomsws6
CF Senior Member
tomsws6's Avatar
Recieved 0 Likes on 0 Posts
Default AK47 guys I need some help
Ok, a friend of a friend is trying to sell me his AK.. I just dont know anything about them or what they are worth.. Here is what I know..
1.Hungarian
2.Manufacture FEG
3.model ** 2000m (sa-2000m??)
4. Serial # SK00518
5.KBL assembled
6. 30 round clip and 100 rounds of ammo
Asking 600.
tomsws6 is offline
Old 03-17-2015, 01:18 AM
Zix
CF Senior Member
Zix's Avatar
Recieved 1 Like on 1 Post
The Hungarian AKs are usually referred to as AMDs. If it is a Hungarian built AMD, then it should be a solid rifle. However, the SA-2000M rifle receivers where originally built for single-stack magazines, they were milled later to accept the high capacity double stack magazines. Sometimes this causes a bit of magazine wobble, but I have never personally seen any functional issues because of it.
That should be the model with the wire-folding stock and reverse pistol grip on the fore-end. I don't like the wire-folders, but that's a personal preference, there are ways to make it "better" if you want to go down that path.
When it comes down to it, $600 is not a bad price with the ammo, but if you're really in the market for an AK-style rifle you can likely find a better deal, or maybe something you like more.
Also, I'm not aware of a builder "KBL", but if this is a built off of a kit I would offer a lot less. They can be nothing but problems if the builder didn't know what they were doing.
Zix is offline
Old 03-17-2015, 01:26 AM
tomsws6
CF Senior Member
tomsws6's Avatar
Trying to upload a short vid of it but it says it is missing the token? It actually has a synthetic stock and it does not have a pistol grip on the forehand.. I really want an AR but it was a blast to shoot and loud as hell.. My initial plan was to buy it and flip it to start an AR build.. Im also trying to get his 1911 he's sellin for 600 too.
tomsws6 is offline
Old 03-17-2015, 07:44 AM
jim2527
CF Senior Member
jim2527's Avatar
Recieved 167 Likes on 147 Posts
In this market? Good luck.
jim2527 is offline
Old 03-17-2015, 08:25 AM
~Josh
CF Senior Member
~Josh's Avatar
Recieved 413 Likes on 313 Posts
Buy it if you want to keep it.
~Josh is offline
Old 03-17-2015, 08:30 AM
SLO VETTE
CF Senior Member
SLO VETTE's Avatar
Recieved 50 Likes on 41 Posts
the police are going to need to see your paperwork on that.
SLO VETTE is offline
Old 03-17-2015, 09:03 AM
shootnstarz
CF Senior Member
shootnstarz's Avatar
Recieved 40 Likes on 31 Posts
If you really want an AR hold out for it, IMHO. I've had many AKs, both 47s and 74s. They are what they are, an assembly of loose parts that usually work flawlessly in any conditions sacrificing accuracy in the process. For me, I was not happy with 3+ moa even on a spray and pray weapon.
ARs are much more refined and are made with more precision. With the right combination they can be made sub moa easily. The trade off is with the tight tolerances comes a tendency to malfunction if the weapon becomes too dirty or is subjected to a lot of dirt/sand/mud ect.
For me the choice was easy, I'm an accuracy shooter, or try to be. If that's your forte' too then hold out for an AR, they're not much more than the $600 price on the Hungy AK.
If you just want to send a lot of lead downrange quickly and don't really care how close to target they impact then an AK would be fine. Again, all just my opinion.
Rick
shootnstarz is offline
Old 03-17-2015, 09:06 AM
breecher_7
CF Senior Member
Recieved 3 Likes on 3 Posts
I would pass. If you really want a AK, look for a good deal on a pre ban norinco.
breecher_7 is offline
Old 03-17-2015, 09:23 AM
ts_vette_st
CF Senior Member
ts_vette_st's Avatar
Recieved 15 Likes on 7 Posts
The old AR vs AK debate. Easy answer ... get both!
ts_vette_st is offline
Old 03-17-2015, 09:33 AM
shootnstarz
CF Senior Member
Really is no debate, like saying which are better, apples or oranges.
They're two completely different weapons both having their pros and cons.
That said "If you know how many guns you have you don't have enough" !
Rick
Old 03-17-2015, 12:07 PM
ZZOOM06
CF Senior Member
ZZOOM06's Avatar
Recieved 4 Likes on 4 Posts
I've had a FEG AK for a very long time. It is the one with the thumbhole stock that was available during the "ban". It has functioned flawlessly and I've put many thousands of rounds downrange with it. As far as accuracy it's no AR, but I can hit a man-sized steel target at 300yards consistently with it. IMO, $600 is too much for one that is used, nowadays you can buy an American made, milled receiver AK with a chrome lined barrel for around $600 brand new. (just pick up a copy of Shotgun News).
If you want to get an AR platform, the Smith & Wesson M&P 15 base model can be had for around $600. HTH
ZZOOM06 is offline
Old 03-17-2015, 02:49 PM
HGUNHNTR
CF Senior Member
Recieved 2 Likes on 2 Posts
Decent deal, and it's a magazine...not a clip.
HGUNHNTR is offline
Old 03-17-2015, 04:24 PM
mikeco
CF Senior Member
mikeco's Avatar
Zix pretty much covered it. If it has FEG on the receiver it was probably imported by TGI as a single stack & opened up to accept a double stack mag. The price with ammo isn't bad but I wouldn't get it just to try and flip it.
Buy it and enjoy the hell out of it then get an AR.
mikeco is offline
Old 03-17-2015, 05:31 PM
Der Flieger
CF Senior Member
Der Flieger's Avatar
Recieved 18 Likes on 6 Posts
Palmetto State Armory sells AR kits + stripped lowers for less than $600 including shipping. I have found them to be very accurate with close-tolerance machine work. If you watch for their weekly specials, you may be able to purchase a nice kit for less. I can assemble one of these puppies in less than an hour, including laser bore-sighting. PSA can sell you ammo cheaper than anyone. Check 'em out.
Der Flieger is offline
Quick Reply: AK47 guys I need some help
Sponsored Ads
Vendor Directory
Contact Us - About Us - Archive - Advertising - Cookie Policy - Privacy Statement - Terms of Service
© 2019 MH Sub I, LLC dba Internet Brands
  • Ask a Question
Question Title:
Description:
