Go Back  CorvetteForum - Chevrolet Corvette Forum Discussion > Off Topic > Off Topic
Reload this Page >
Small engine gurus: 2 Cycle engines - how much oil is too much?
Off Topic Off Topic | Non-Corvette
Old 06-01-2015, 05:38 PM
wamara
CF Senior Member
wamara's Avatar
Liked 13 Times in 11 Posts
Cruise-In II Veteran
Default Small engine gurus: 2 Cycle engines - how much oil is too much?
Just bought a new string trimmer which calls for 3.2 oz. of oil per 1 gallon of gasoline. I won't go through a gallon of gas for the entire summer, and the owner's manual repeatedly warns against using "old gas", so I filled up my gas can with a 1/2 gallon of gas, with the idea that I will add 1.6 ounces of oil. The trick for me will be measuring this amount of oil. I looked up a conversion chart and 2 tablespoons equals 1 fluid ounce, so 3 tablespoons will equal 1.5 ounces. leaving me with figuring out the remaining one-tenth of an ounce. I don't know how critical and exact you need to be here; I'll assume that you don't want to have less oil than is called for, but how bad would it be if I put too much oil (guesstimating the .1 oz) in the fuel? Thanks for any cogent replies
wamara is offline
Old 06-01-2015, 05:40 PM
BOTYNV1
CF Senior Member
BOTYNV1's Avatar
Liked 83 Times in 61 Posts
St. Jude Donor '09-'10-'11-'12-'13-'14-'15-'16-'17-'18-'19
Too much it will smoke.
BOTYNV1 is offline
Old 06-01-2015, 05:49 PM
wamara
CF Senior Member
wamara's Avatar
So other than some air pollution and possibly fouling the spark plug, it shouldn't be a problem as far as any engine damage? I could get very, very close using teaspoon measures, but my wife would take a very dim view to my using her kitchen measuring spoons
wamara is offline
Old 06-01-2015, 05:51 PM
DJ_Critterus
CF Senior Member
DJ_Critterus's Avatar
Location: FL.... America's Wang! No shrinkage. Winter's not coming!
Liked 75 Times in 46 Posts
St. Jude Donor '09
A little over won't hurt it like running it too lean will.
DJ_Critterus is offline
Old 06-01-2015, 05:58 PM
Silverspeed
CF Senior Member
Silverspeed's Avatar
Liked 20 Times in 9 Posts
St. Jude Donor '13, '15
.1 ounce of oil in 64 ounces makes up .156% of the mixture. In other words, gas pumps have a greater margin of error than that, and there is no way you can be assured that you have EXACTLY 64 ounces, nor can you measure the oil you pour that exact, so it won't matter. Add a couple of extra drops if you want to sleep well at night.
Silverspeed is offline
Old 06-01-2015, 06:02 PM
The_Dude
CF Senior Member
The_Dude's Avatar
Liked 147 Times in 71 Posts
St. Jude Donor '11, '16-'17
Just buy good oil. Some of the synthetics claim to be safe at 100:1. I used to run Optimol at 80:1 in a chainsaw, 6 hours a day, 7 days a week for 3 week stints.
The_Dude is online now
Mick71
CF Senior Member
Mick71's Avatar
Liked 11 Times in 10 Posts
St. Jude Donor '13-'14-'15
Actually, more oil makes a leaner mixture, more oil = less fuel.
OP, as long as you're pretty close, a tenth of an oz. won't be an issue.
32 to 40:1 is what you want with modern synthetics.
Mick71 is offline
Old 06-01-2015, 06:04 PM
Silverspeed
CF Senior Member
Or just buy this and don't worry about all that mess.
http://www.lowes.com/pd_50786-442-65...ductId=3456458
LarryMJones
CF Senior Member
LarryMJones's Avatar
Liked 2 Times in 2 Posts
St. Jude Donor '13-'14-'15-'16-'17
Mix up a gallon it's easier to do the math.
LJ
LarryMJones is offline
Old 06-01-2015, 06:22 PM
BOTYNV1
CF Senior Member
BOTYNV1's Avatar
Don't sweat it, I have been eyeballing it for years w/out measuring at all. I only go through three or so trimmers a year J/K you will be close enough with your measuring to be fine.
BOTYNV1 is offline
Old 06-01-2015, 06:26 PM
Dave concrete
CF Senior Member
Dave concrete's Avatar
Liked 41 Times in 36 Posts
32:1 odd for most of today's small stuff, most are 50:1 which is 2.6oz to a gallon.
You are better off buying pre-mixed fuel already comes done, zero ethanol and a two year shelf life. Most small equipment shops have it and home depot as well.
Dave concrete is offline
Old 06-01-2015, 06:28 PM
Dave concrete
CF Senior Member
I remember when that stuff came out right around 89' 90' it was the big thing in the day for 2 cycle.
Old 06-01-2015, 06:33 PM
The_Dude
CF Senior Member
The_Dude's Avatar
This was probably about '85 or '86. The saw shop sold me the stuff with the saw. I never had a problem with it. I'm not brave enough for 80:1 anymore. I use synthetic and mix 50:1 these days.
Old 06-01-2015, 06:39 PM
wamara
CF Senior Member
wamara's Avatar
Dave,
the engine does call for a 40:1 ratio. They even gave me a tiny bottle of synthetic oil - of course, it was 3.2 oz. I have a gas station that sells 89 octane fuel with no ethanol; that is what I'm using for the trimmer. Unless manufacturers have changed materials, it seems like a lot of people are at least under the impression that the ethanol really chews up the plastic in the engine (fuel lines, etc.) Thanks everyone for the replies.
wamara is offline
Old 06-01-2015, 06:43 PM
Silverspeed
CF Senior Member
Dave,
the engine does call for a 32:1 ratio. They even gave me a tiny bottle of synthetic oil - of course, it was 3.2 oz. I have a gas station that sells 89 octane fuel with no ethanol; that is what I'm using for the trimmer. Unless manufacturers have changed materials, it seems like a lot of people are at least under the impression that the ethanol really chews up the plastic in the engine (fuel lines, etc.) Thanks everyone for the replies.
There are 128 ounces in a gallon, so if that tiny bottle says add to 1 gallon, its a 40:1 ratio.
Old 06-01-2015, 06:44 PM
Dave concrete
CF Senior Member
Dave,
Ethanol kills the internals of Carbs on both 2 and 4 cycle motors. We rebuild carbs about every 3 months on all the cut off saws and blowers.
We add a cap full of a chemical that helps and 93 is a must.
My ICS concrete chainsaws run 25:1 talk about smoke and fumes.
Old 06-01-2015, 07:16 PM
carsangelop
CF Senior Member
carsangelop's Avatar
Liked 4 Times in 3 Posts
I just got a 4 stroke This thing is really powerful and starts on the 1st or 2nd pull Great machine and no mixing or excessive smoke
carsangelop is offline
Old 06-01-2015, 07:37 PM
wamara
CF Senior Member
wamara's Avatar
Well, this is what happens when I'm relying on my memory - got the numbers mixed up in my head, double checked the manual, and it does say 40:1 ratio
wamara is offline
Old 06-01-2015, 11:48 PM
psychodiagnostik
CF Senior Member
psychodiagnostik's Avatar
I have a 15 year old weed trimmer that I've used 10 years.
I always eyeball the approx. amount of oil per gallon that I calculate according to the specs... then add another couple oz. per gallon. I don't think it's super critical but I've always figured it's better to go over a little on the oil.
Yes it smokes but I'm still running the same plug since I got it & it runs good. What I have done is rebuild the little zama carb with the $7 rebuild kit every couple of summers. This seems to keep it running good (primes easy, starts easy, warms up & runs off choke fast).
Some people like to run ethanol free in trimmers, chainsaws, etc & there's a station locally that sells it but I seem to do OK with regular gas. But who knows maybe with ethanol free I wouldn't be needing the carb rebuilds, I've heard the ethanol hurts the diaphragm in the carb.
psychodiagnostik is offline
Old 06-02-2015, 12:09 AM
BobbyC3
CF Senior Member
BobbyC3's Avatar
Location: Common courtesy and common sense are not common.
Liked 0 Times in 0 Posts
got a 25 year old Lawn Boy that I run with a shot glass of oil in the gas can for years. Still running strong
BobbyC3 is offline
Quick Reply: Small engine gurus: 2 Cycle engines - how much oil is too much?
Sponsored Ads
Vendor Directory
Contact Us - About Us - Archive - Advertising - Cookie Policy - Privacy Statement - Terms of Service
© 2019 MH Sub I, LLC dba Internet Brands
  • Ask a Question
Question Title:
Description:
