Off Topic Off Topic | Non-Corvette
07:16:04
Old 06-23-2017, 05:54 PM
  #81
C5 Hardtop
CF Senior Member
C5 Hardtop's Avatar
Originally Posted by chaase View Post
It could be that. It could be a issue with chassis tuning. It could be tire pressure. It could be that he is just pushing the car to the very edge and that is how that car reacts. It just looks like he is working harder than I recall drivers having to work the Corvettes.
The dude has serious skills because he is keeping it shiny side up on a very, very hard track.
EDIT: Here is a C6 ZR1 video. He doesn't seem to have to fight the vette as much as the Camaro. I am wondering if the Camaro is just a bit more tail happy than the vette.
https://www.youtube.com/watch?v=h5gyUCOD-tc
I'm not a betting man, but I'd bet you a nickel the driver in the OP vid in that ZR1 would beat the Camero on the same track.
C5 Hardtop is offline
Old 06-23-2017, 06:06 PM
  #82
RollaMo-LT4
CF Senior Member
RollaMo-LT4's Avatar
St. Jude Donor '10-'11-'12-'13-'14-'15-'16-'17-'19
Originally Posted by JoesC5 View Post
What is the gearing of the regular ZL1 and the ZL1 1LE?
The rear end gears are the same @ 3.73
The regular ZL1 has a posted top speed of 198.
General consensus on the Camaro forum, is the 1LE version will be less than that do to the transmission gearing being different.
I can't find actual specs on the transmission gearing, except for this:
TREMEC six-speed manual with Active Rev Match (with 1LE-specific top gear ratio)
RollaMo-LT4 is offline
Old 06-23-2017, 06:12 PM
  #83
RollaMo-LT4
CF Senior Member
Originally Posted by PKguitar View Post
If you look at his rpms at that speed, he has the redline to go over 200. Don't know if he has the power that high in the power band though.
It does look that way.
But he also ran out of straight away, which put an end to him gaining any more speed.
Given enough room he might have made 200, but I doubt it.
Old 06-23-2017, 06:28 PM
  #84
VatorMan
CF Senior Member
VatorMan's Avatar
CI 6-7-8 Veteran
St. Jude's Donor '06-'10-'11, '15
Originally Posted by ptindall View Post
99% of the time when someone is really smooth, they are simply going too slow to need to control the car on the limit. And this is a 650hp car on street tires at the ring. Smooth ain't happening unless you are driving too slow.
I've had John Heinricy and Andy Pilgrim both tell me that exact thing. If you aren't on the edge every single turn, you left time out there.
VatorMan is offline
Old 06-23-2017, 06:30 PM
  #85
lrobe22
CF Senior Member
lrobe22's Avatar
St. Jude Donor '15
The transmission gearing on the ZL1 1LE does look very tight, very tight shifts.
lrobe22 is offline
Old 06-23-2017, 06:36 PM
  #86
Sky High
CF Senior Member
Sky High's Avatar
You beat me to it. The ZR1 driver (Jim Mero) in the 7:19:63 ZR1 video seems to drive that car a little less recklessly and more timid. Put that Camaro driver in the ZR1 and lights out. BTW the driver is Bill Wise, a GM handling engineer.
Sky High is offline
Old 06-23-2017, 07:31 PM
  #87
FourPennyDoug
CF Senior Member
Support Corvetteforum!
FourPennyDoug's Avatar
I've watched a few minutes of the ZL1 and ZR1 videos and to me it seems like the ZR1 is more out of control. It certainly had just as much tire squeal yet was 10 seconds slower.
I know this is subjective but I would not say there is a substantial difference in each video in regards to how much the driver has to fight their car.
FourPennyDoug is offline
Old 06-23-2017, 07:43 PM
  #88
Sky High
CF Senior Member
Sky High's Avatar
It was three and a half seconds slower. 7:19:63 - 7:16:04 BTW the record lap (at the time for GM) in the ZR1 was the second ZR1 video not the first and the tires in that video hardly squeal compared to the Camaro.
Sky High is offline
Old 06-23-2017, 07:52 PM
  #89
TwoSmoke
CF Senior Member
TwoSmoke's Avatar
The ZR1 was on production-spec Michelin Pilot tires.
The camaro was on production-spec Goodyear Eagle F1 Supercar 3R tires.
I have no idea what that difference would mean on lap times.
TwoSmoke is offline
Old 06-23-2017, 08:42 PM
  #90
Dave concrete
CF Senior Member
Dave concrete's Avatar
Originally Posted by lionsfan5454 View Post
outlaps a F488 but "needs more refinement"
Watch ANY ring video and that amount of fighting is pretty standard. It's an incredibly tough track, regardless of the car.
I know, i don't care if the car punched him in the face, he beat up on cars 4x more. TO CHEVY
Dave concrete is offline
Old 06-23-2017, 10:00 PM
  #91
themonk
CF Senior Member
themonk's Avatar
Location: Calgary, AB. There's a reason why white was the only color offered on every year Corvette. Proud Canadian German Jamaican!
St. Jude Donor '09, '12-'13-'14-'15-'16-'17
I guarantee you that if Sabine Schmitz was driving that 4 Penny, she would've bettered that time.
themonk is offline
Old 06-23-2017, 10:06 PM
  #92
themonk
CF Senior Member
themonk's Avatar
Really? Well I'm looking at Sabine and it doesn't look like she's fighting the car at all, smooth as silk in fact.
themonk is offline
Old 06-23-2017, 10:07 PM
  #93
Z06PSI
1SG of the Goon Squad
Z06PSI's Avatar
St. Jude Donor '17-'18
Z06PSI is offline
Old 06-23-2017, 10:17 PM
  #94
themonk
CF Senior Member
themonk's Avatar
Originally Posted by Z06PSI View Post
do you even track bro?
hey haole, this tread is about performance cars on a track, what are you doing in here? Go back to picking pineapples papaya boy.
themonk is offline
Old 06-23-2017, 10:27 PM
  #95
Z06PSI
Z06PSI's Avatar
Sabine is old and washed up. Her time passed 10 years ago.
Or do not get news up there in yakfuckland?
Z06PSI is offline
Old 06-23-2017, 10:30 PM
  #96
themonk
CF Senior Member
themonk's Avatar
she would wipe your *** on a track......why, because she's German.
themonk is offline
Old 06-23-2017, 10:35 PM
  #97
Z06PSI
Z06PSI's Avatar
Nice reach. Must have hit your 3 beer limit already.
Z06PSI is offline
Old 06-23-2017, 10:37 PM
  #98
themonk
CF Senior Member
themonk's Avatar
Fact =/= Reach
And don't worry about my beer count, have a Coke and a smile and shut the f'k up.
themonk is offline
Old 06-24-2017, 12:07 AM
  #99
MickP
CF Senior Member
MickP's Avatar
Here's another guy who obviously has no skills. I'm sure the guys he's blowing into the weeds are smoother.
https://www.youtube.com/watch?v=JTGvHskGKI4
No helmet?
MickP is offline
Old 06-24-2017, 12:53 AM
  #100
Little Red L98
Goon Squad BS Detector
Little Red L98's Avatar
2018 C4 of the Year Winner
2017 C4 of the Year Finalist
St. Jude Donor '15, '17
Dayum!
Little Red L98 is offline
Quick Reply: 07:16:04
Sponsored Ads
Vendor Directory
Contact Us - About Us - Archive - Advertising - Cookie Policy - Privacy Statement - Terms of Service
© 2019 MH Sub I, LLC dba Internet Brands
  • Ask a Question
Question Title:
Description:
