Off Topic Off Topic | Non-Corvette
Outdoor faucet...
Old 04-27-2018, 01:00 PM
alamike
CF Senior Member
alamike's Avatar
Originally Posted by Scoob View Post
That's why you shut off the supply to outside spigots and then open them for the winter.
In the south, isolation to bibs is not typical or required by code. To do what you are proposing for my present house in Alabama, I would have to reroute the plumbing to the Bibs. I have been insulating covers on the bibs and leaving the water dripping during cold snaps. So far in the last thirty years no problems.
alamike is offline
Old 04-27-2018, 01:01 PM
Voytek
CF Senior Member
Voytek's Avatar
Voytek is online now
Old 04-27-2018, 01:02 PM
96 Vette CE
Banned Loser
Support Corvetteforum!
96 Vette CE's Avatar
Location: Up Here In Patriots Nation Drinking The Haters Tears
2017 Corvette of the Year
2016 C4 of Year Finalist
Creator of the "Original" whining and crying thread
St. Jude Donor '14-'15-'16-'17
Enough of your complicated mumbo jumbo, can you put it in layman's terms for Voy?
96 Vette CE is offline
Old 04-27-2018, 01:19 PM
Scoob
CF Senior Member
Scoob's Avatar
Could you install one of these on the line to the spigot? They're also helpful when going away on vacation so neighbors, contractors, and landscapers can't "borrow" your water while you're away.
Scoob is offline
Old 04-27-2018, 01:20 PM
Scoob
CF Senior Member
Scoob's Avatar
"call a plumber to fix it"
how's that?
Scoob is offline
Old 04-27-2018, 01:23 PM
96 Vette CE
Banned Loser
how's that?
Old 04-27-2018, 01:25 PM
cdngolfer
CF Senior Member
cdngolfer's Avatar
Originally Posted by Voytek View Post
OK. As long as the outer tube is not leaking, you can just replace the guts.
These frostproof hose bibs are used so that during freezing conditions, they can be opened to get water. The seat is inside where its warmer. After the valve is shut, the outer tube must be allowed to drain or the water will freeze and push back against the closed seat causing a burst that will not be discovered until the valve is opened again.
cdngolfer is offline
Old 04-27-2018, 01:28 PM
VandelayIndustries
CF Senior Member
VandelayIndustries's Avatar
"*ask your wife to call a plumber to fix it"
how's that?
VandelayIndustries is online now
JetMechZ16
CF Senior Member
JetMechZ16's Avatar
Get a man to fix it for ya.
JetMechZ16 is offline
Old 04-27-2018, 01:35 PM
96 Vette CE
Banned Loser
Thanks bro, see post #2
Old 04-27-2018, 01:39 PM
427 Z
Tijuana Event Coordinator
427 Z's Avatar
St. Jude Donor '10-'11-'12-'13-'14-'15-'16-'17-'18-'19
Time for new washers
427 Z is online now
Old 04-27-2018, 01:52 PM
tomc8at
CF Senior Member
tomc8at's Avatar
I have nothing going on tonight.. send me an airline ticket...
But NOT Southwest and make it 1st class.
And I will reroute your whole house, pics of wife plz
tomc8at is offline
Old 04-27-2018, 02:08 PM
  #33
flange
CF Senior Member
flange's Avatar
St. Jude Donor '14
I have nothing really to add that hasn't been said. I just came by to see what you messed up this time.
Try tightening the packing nut, or replace the valve, its simple, even a voy can do it.
flange is offline
Old 04-27-2018, 02:12 PM
  #34
96 Vette CE
Banned Loser
Old 04-27-2018, 02:13 PM
  #35
427 Z
427 Z's Avatar
427 Z is online now
Old 04-27-2018, 02:14 PM
  #36
gilhuly
CF Senior Member
gilhuly's Avatar
on a side note:
if you have a basement and you live where it freezes, never insulate where the hose bib exits the house.
you want that area around the bib to get ambient heat.
don't ask how I know.
gilhuly is offline
Old 04-27-2018, 02:17 PM
  #37
Der Flieger
CF Senior Member
Der Flieger's Avatar
I did turn it off for the winter. Not leaking on the inside. Maybe the washers dried up.
Simple faucet and they make it so complex
It's not the "faucet", (hose bib), that is simple.
Der Flieger is offline
Old 04-27-2018, 02:25 PM
  #38
MAD IN NC
CF Senior Member
MAD IN NC's Avatar
Crowd Plow For Now
Wwaf2d?
MAD IN NC is online now
Old 04-27-2018, 02:27 PM
  #39
VandelayIndustries
CF Senior Member
Originally Posted by MAD IN NC View Post
Wwaf2d?
Replace it with this
Old 04-27-2018, 02:38 PM
  #40
kingpin111
CF Senior Member
kingpin111's Avatar
Water leaking from the stem means o-ring replacement that is on the stem when you pull it out. Water leaking from the spout means replacement washer on the bottom of the stem usually held on buy a screw and/or seat replacement.
Replace both while you're at it.
kingpin111 is offline
Quick Reply: Outdoor faucet...
Sponsored Ads
Vendor Directory
Contact Us - About Us - Archive - Advertising - Cookie Policy - Privacy Statement - Terms of Service
© 2019 MH Sub I, LLC dba Internet Brands
  • Ask a Question
Question Title:
Description:
