Off Topic Off Topic | Non-Corvette
Outdoor faucet...
Old 04-27-2018, 12:25 PM
Voytek
CF Senior Member
Voytek's Avatar
Default Outdoor faucet...
Why is water coming out of the stem? Do I need to buy a whole new assembly or just replace the stem?
Voytek is offline
96 Vette CE
Banned Loser
Support Corvetteforum!
96 Vette CE's Avatar
Location: Up Here In Patriots Nation Drinking The Haters Tears
2017 Corvette of the Year
2016 C4 of Year Finalist
Creator of the "Original" whining and crying thread
St. Jude Donor '14-'15-'16-'17
Time for new washers
96 Vette CE is offline
Old 04-27-2018, 12:26 PM
Jughead
Senior Member since 1492
Jughead's Avatar
Location: 1.Just because I'm paranoid doesn't mean people aren't out to get me... 2.Build the WALL!
St. Jude Donor '09
you're fucked.
Jughead is offline
Old 04-27-2018, 12:27 PM
Humanoid 2.0
CF Senior Member
Humanoid 2.0's Avatar
Cruise-In VII Veteran
St. Jude Donor '05-'06-'07-'08-'09-'10-'11-'12-'13-'14-'15-'16-'17-'18
You left it on during the winter
Humanoid 2.0 is offline
Old 04-27-2018, 12:28 PM
BadUmp
CF Senior Member
BadUmp's Avatar
hmmmm - - - don't suppose you gave any thought to putting a pair of vise grips on that nut and try tightening to see if that would work . . .
BadUmp is online now
Scoob
CF Senior Member
Scoob's Avatar
pretty obvious
Scoob is offline
Old 04-27-2018, 12:30 PM
Rodnok1
CF Senior Member
Rodnok1's Avatar
That's a frost proof (lol) unit. Have to take the innards out to see manufacturer and get a match. Last 2 I've fixed ended up replacing whole dealio...
Rodnok1 is offline
red1vette
CF Senior Member
red1vette's Avatar
needs a rebuild kit
red1vette is offline
Old 04-27-2018, 12:31 PM
427 Z
Tijuana Event Coordinator
427 Z's Avatar
St. Jude Donor '10-'11-'12-'13-'14-'15-'16-'17-'18-'19
tighten the packing nut
427 Z is online now
Old 04-27-2018, 12:37 PM
Swany00
CF Senior Member
Swany00's Avatar
keep up the good work Voy!
No wonder your wife fired your ***
Swany00 is offline
Old 04-27-2018, 12:40 PM
alamike
CF Senior Member
alamike's Avatar
I would check if it is leaking from inside too. One year in East Tenn, we had a record breaking cold snap and inside of the hose bib cracked. It didn't leak until I opened it the next spring. If you didn't insulate it last winter, the bib my be cracked.
alamike is offline
Old 04-27-2018, 12:41 PM
Docbrock
CF Senior Member
Docbrock's Avatar
Docbrock is offline
Old 04-27-2018, 12:42 PM
sublime1996525
CF Senior Member
sublime1996525's Avatar
This! Never leave you hose hooked up. When it freezes, you're fucked.
sublime1996525 is offline
cdngolfer
CF Senior Member
cdngolfer's Avatar
Try a Plumbing forum
However, if you left it open during the winter, with the hose attached, it has likely burst the exterior tube inside the wall and is leaking internally when the valve is open. Therefore replacement of the whole frostproof hose bibb is required. Listen for a sound of running water inside your house. Otherwise, the packing nut could be tightened or removed to replace the gasket/packing.
I have investigated dozens of these. Its always caused by leaving your hose connected and full of water that freezes and pushes back into the valve seat that is about 12 inches from the handle, inside the wall.
cdngolfer is offline
Voytek
CF Senior Member
Voytek's Avatar
I did turn it off for the winter. Not leaking on the inside. Maybe the washers dried up.
Simple faucet and they make it so complex
Voytek is offline
Old 04-27-2018, 12:43 PM
cdngolfer
CF Senior Member
cdngolfer's Avatar
Its not leaking from the hose connection washer
Old 04-27-2018, 12:46 PM
HBsurfer
CF Senior Member
HBsurfer's Avatar
O rings. Should be an easy fix
HBsurfer is offline
Old 04-27-2018, 12:48 PM
VandelayIndustries
CF Senior Member
VandelayIndustries's Avatar
Wasted a couple hours with mine last summer taking it apart, trying to find the right washers, etc. Finally gave up and replaced the whole thing...$35 and 20 minutes later I was done.
VandelayIndustries is online now
Old 04-27-2018, 12:49 PM
Scoob
CF Senior Member
Scoob's Avatar
That's why you shut off the supply to outside spigots and then open them for the winter.
Scoob is offline
Old 04-27-2018, 12:57 PM
Jughead
Jughead's Avatar
St. Jude Donor '09
washers
Jughead is offline
Quick Reply: Outdoor faucet...
Sponsored Ads
Vendor Directory
Contact Us - About Us - Archive - Advertising - Cookie Policy - Privacy Statement - Terms of Service
© 2019 MH Sub I, LLC dba Internet Brands
  • Ask a Question
Question Title:
Description:
