Go Back  CorvetteForum - Chevrolet Corvette Forum Discussion > Off Topic > Off Topic
Reload this Page >
What an experience - Do yourself a favor and don't ask about ionizers on poolforum
Off Topic Off Topic | Non-Corvette
Old 08-12-2018, 03:42 PM
J S Machine
CF Senior Member
J S Machine's Avatar
St. Jude Donor '10-'11-'12-'13-'14-'15-'16-'17
St. Jude Knife Maker
Originally Posted by ZO ZICK View Post
Set it up close to the house!
Kids will love it.
It is close but not that close. It's about 6' from the back porch. I built a small deck between it and the house. Turned out really nice.
Originally Posted by need-for-speed View Post
Try this site. From my limited experience itís been a very friendly place with quite a bit of traffic / hence, answers to your questions.
No guarantees the answer wonít be the same, but theyíll be nice about it
https://www.troublefreepool.com/cont...-TFP-Home-Page
I will check it out.
Originally Posted by centuryoldracer View Post
I had above ground pools, and the best thing I ever did was use a winter cover year round for numerous reasons. It keeps the sun from turning the water green (nothing grows in the dark, my cover was black), prevents evaporation, and chemical loss cutting the chemical use 80% or more, and because it goes over the edges of the pool, and draws tight, it keeps every bit of crap from blowing or falling into the pool like tree leaves. Also the dark cover worked as a solar heat, and they are cheap.
In-laws gave us a tarp big enough to cover it. I will do that for sure for starters. If it gives a good bit of trouble I will look into one of the nicer covers. We might have until the end of September here in AL if that long. I don't know if it is common for all above grounds to be cooler, but seems to be a trend from what I have heard and seen. It is in the 90's outside, and even though it is in partial shade, it is still no higher than 80 degrees. A little chilly.
Originally Posted by Voytek View Post
Iím on troublefreepool. Nice people over there.
BBB is no longer recommended. Basically just chlorine and acid to maintain pool once all the other numbers are in spec.
I will check it out. My limited experience with chemicals is basically YouTube. I bought a drop test kit. Alkalinity way low, used baking soda to bring it up, and then chlorinated. It is fine for now. PH is good. I know it won't always be this way though.
J S Machine is offline
Old 08-12-2018, 03:46 PM
RIKKI Z-06
CF Senior Member
RIKKI Z-06's Avatar
Originally Posted by Strats-N-Vettes View Post
I think it's time for OT to join that forum.
Hell yeah, let's do this.
RIKKI Z-06 is offline
Old 08-12-2018, 03:51 PM
KarlK
CF Senior Member
KarlK's Avatar
Originally Posted by NoOne View Post
Did you send him an application to moderate C7 Gen?
KarlK is offline
Old 08-12-2018, 03:52 PM
Z06PSI
1SG of the Goon Squad
Support Corvetteforum!
Z06PSI's Avatar
St. Jude Donor '17-'18
Almost as bad as opening a dead dog thread in CFOT.
Z06PSI is offline
Z06PSI
Z06PSI's Avatar
Z06PSI is offline
dvarapala
Making CFOT Great Again
dvarapala's Avatar
Subscribed.
http://www.poolforum.com/pf2/showthr...Can-t-I-Search
dvarapala is online now
Old 08-12-2018, 04:53 PM
J S Machine
CF Senior Member
Originally Posted by dvarapala View Post
reply to that and say you want to use the forum search feature, not his Google link crap.
Old 08-12-2018, 05:42 PM
NoOne
CF Senior Member
NoOne's Avatar
Anyone want to tell him the date is WAY OFF on the forum?
NoOne is offline
Old 08-12-2018, 10:10 PM
Voytek
CF Senior Member
Voytek's Avatar
What do you use to chlorinate?
I recommend plain ol' bleach. Just make sure it's not scented nor any other fancy laundry additives. I buy my liquid chlorine at a pool store but they have them at walmart, target, etc...
Voytek is offline
Old 08-12-2018, 10:18 PM
Chambered
CF Senior Member
Chambered's Avatar
Just trun a plugged-in hair dryer in the pool while people are in it - I think that's what the ogre was thinking you meant when you posted. Pretty funny development after your initial post. THREAD CLOSED! HaHaHa!
Chambered is offline
Old 08-12-2018, 11:29 PM
J S Machine
CF Senior Member
Alkalinity was down so added sodium bicarb to get that up. Then put in one GAL liquid bleach, followed by two of the packets of chlorine shock granules. It is still showing less than .5ppm on drop test though, so needs more for sure. Cleared the water up nice but I know the level needs to be higher. Ph is good.
Old 08-13-2018, 12:02 AM
Voytek
CF Senior Member
Voytek's Avatar
Give this a read. https://www.troublefreepool.com/cont...ater-chemistry
You need CYA in your pool. It is a sunblock for chlorine, otherwise the sun will eat the chlorine up fast. You generally want to be around 50ppm CYA. Then you will maintain your chlorine at 6-8.
If you lose more than 1ppm of chlorine during the night, then you should shock. Shocking is bringing chlorine up to a shock level and maintaining that until you pass the overnight test.
Here is the cya/fc chart https://www.troublefreepool.com/cont...art-slam-shock
It's pretty simple once you get the water correct. I only add chlorine a few times a week and acid a couple times a month.
Voytek is offline
Old 08-13-2018, 12:03 AM
  #33
Voytek
CF Senior Member
Voytek's Avatar
No one seems to like ionizers anymore but salt water generators are quite popular. They convert salt into chlorine so you don't have to add liquid chlorine regularly.
Voytek is offline
Old 08-13-2018, 06:51 AM
  #34
cuisinartvette
CF Senior Member
St. Jude Donor '05
Nver heard of BBB...simple test kits all ya need. You use baking soda not soda ash to raise ph?
I can see the mods point, could be a liability. Someone will screw it up and fry themselves.
Guy here wrecked his car yrs ago accused a member of trying to kill him. Guy was being a smartass on a brake fluid thread so he was told water could be put in and stop the car, which it did. For a bit. LOL
Sometimes even in Salt Pools you need a litlle liquid. Use "conditioner" to protect the chlorine from the sun .Cheap and it works, ck it 2x a yr
cuisinartvette is offline
Old 08-13-2018, 08:38 AM
  #35
bonnevillebill
CF Senior Member
bonnevillebill's Avatar
That mod was a tool.
bonnevillebill is offline
Old 08-13-2018, 09:36 AM
  #36
Railroadman
CF Senior Member
Railroadman's Avatar
St. Jude Donor '09-'10-'11-'12-'13-'14-'15-'16-'17-'18-Ď19
That was kinda like someone coming on CFOT and asking about the C-4 he just bought!
Around here putting n00bs through the wringer is just the way it's done. Why is anyone surprised or hurt when it works the same way on some other forum?
Railroadman is offline
Old 08-13-2018, 10:42 AM
  #37
dvarapala
dvarapala's Avatar
Here it's just good-natured ball-busting. That guy is a complete idiot and takes himself way too seriously.
Old 08-13-2018, 10:56 AM
  #38
VandelayIndustries
CF Senior Member
VandelayIndustries's Avatar
VandelayIndustries is offline
Old 08-13-2018, 11:41 AM
  #39
sublime1996525
CF Senior Member
sublime1996525's Avatar
The mods a tool. Lets crash the forum and all join!!
sublime1996525 is offline
Old 08-13-2018, 11:48 AM
  #40
J S Machine
CF Senior Member
Y'all, this crap just doesn't end. I would be lying if I said I wasn't a little bit upset about how I was treated with his responses and just locking my thread. I think I mentioned trying to pm him to ask about the whole situation, but I couldn't even do that. I did not even have access to view his profile and was not able to even send a pm, so I went to the only place I had access to which was apparently some forum where he lets every thread go, then he just moves them to the right place.
So I posted a thread, and I asked for him to please contact me by email. Even though I was upset, so was polite about it. I don't know exactly what I was going to do other than simply discuss why he is so bent, and just try to smooth things out. Anyway, I get an email this morning....
look at this crap:
So then I go try to log in and see if I can see the thread I posted where I asked if he would please email me. I was going to screenshot it so you all could see it. Then I get this crap:
I'm just beside myself. I don't even know how to react to this.
Quick Reply: What an experience - Do yourself a favor and don't ask about ionizers on poolforum
Sponsored Ads
Vendor Directory
Contact Us - About Us - Archive - Advertising - Cookie Policy - Privacy Statement - Terms of Service
© 2019 MH Sub I, LLC dba Internet Brands
  • Ask a Question
Question Title:
Description:
