Off Topic Off Topic | Non-Corvette
Backyard Project
Old 08-30-2018, 03:14 PM
  #41
ThePirate
CF Senior Member
ThePirate's Avatar
Liked 4 Times in 3 Posts
Originally Posted by Knooger View Post
With just a quick glance I think I spotted about 65,000 code violations.
Don't forget the HOA violations.
ThePirate is offline
Old 08-30-2018, 03:28 PM
  #42
utah997
Circles are Hard
Support Corvetteforum!
utah997's Avatar
Liked 23 Times in 11 Posts
St. Jude Donor '07-'08-'09-'10-'11-'12-'13
Originally Posted by Dodosmike View Post
Looks good! Tin and the colours give it the beach vibe.
How'd ya sheet the back wall with it up against the fence? Or is it open?
Generac and pool heater vented together?
Yellow part looks like an outhouse. Does it have a bidet too?
Yeah, the back was a challenge, basically built it around the equipment in place. The framing goes all around, but the tongue and groove only goes just below fence level on the back. So there is some air movement there. Basically on the inside, the fence is the back wall.
Yes, heater and generator are vented together. The yellow part is a 5x5 changing room. Wood slat floor, tongue and groove walls, got a bench inside with some storage, and a bunch of hooks on the wall for clothes/swimsuits to dry etc. Wired a light with switch inside as well.
utah997 is offline
  #43
utah997
Circles are Hard
utah997's Avatar
Originally Posted by Patsgarage View Post
Looks good.
(CFOT ballers) Where are the marble floors and the gold plated toilet ? (CFOT ballers).
You should see the basement....
utah997 is offline
Old 08-30-2018, 03:29 PM
  #44
utah997
Circles are Hard
utah997's Avatar
If we had an HOA in my neighborhood, I would have been killed years ago and hung on a post at the end of my street as an example to others...
utah997 is offline
Old 08-30-2018, 03:40 PM
  #45
VatorMan
CF Senior Member
VatorMan's Avatar
Liked 9 Times in 6 Posts
CI 6-7-8 Veteran
St. Jude's Donor '06-'10-'11, '15
" HEY !! Put that F'n phone down and get your butt back to work!"
{Utah] "But Dad....I MUST post this on CFOT !! I finally figured out how to use focus !!"
VatorMan is offline
Old 08-30-2018, 03:45 PM
  #46
KarlK
CF Senior Member
KarlK's Avatar
Liked 27 Times in 16 Posts
KarlK is offline
Old 08-30-2018, 03:56 PM
  #47
KarlK
CF Senior Member
KarlK's Avatar
and BTW Utah, this is the crap OT's had to put up with since you've been gone;
KarlK is offline
Old 08-30-2018, 04:49 PM
  #48
utah997
Circles are Hard
utah997's Avatar
Originally Posted by KarlK View Post
Holy Crap!
utah997 is offline
Old 08-30-2018, 04:50 PM
  #49
utah997
Circles are Hard
utah997's Avatar
Cliffs please? For whatever reason, the pic of the car and tennis gear seems extremely douchey..
utah997 is offline
Old 08-30-2018, 05:00 PM
  #50
tikiman
CF Senior Member
tikiman's Avatar
Liked 3 Times in 3 Posts
I have the same Generac. From the manufacturer: While the back of the generator can sit as close as 18 in. from your home, surfaces closer than three feet from the front and sides of the generator can impede air flow and cause the unit to overheat. Keep these three sides as well as the top of the generator at least three feet from any wall, standing structure or large object, such as lawn furniture, to ensure the generator is able to optimally perform and stay cool at all times.
I was thinking of building a fence around my pool filter as well, but the electrician installing the Generac informed me that I would be breaking several codes if I did that. Nothing flammable within three feet.
How are you going to change the oil in that thing? The front of the unit has to come off, you know.
tikiman is offline
Old 08-30-2018, 05:10 PM
  #51
utah997
Circles are Hard
utah997's Avatar
Ah.. I see. A detail guy.
Well, we diconnected the generator and flipped it around facing the other way. There is enough room in front to access the engine and do anything we need. I installed a tan metal air vent in the fence right next to the generator. In addition, the heat is plumbed now to vent out the top. I also have two fans mounted inside that are plugged into the generator. If it's running, those fans are running.
Could it overheat. Possibly. But I ran it for three hours with no issues. But yeah, you know. What the Hell do I know?
utah997 is offline
Old 08-30-2018, 05:13 PM
  #52
KarlK
CF Senior Member
KarlK's Avatar
damn, when I saw that exhaust stack, thought you might be using it as weed or meat curing shed..
KarlK is offline
Old 08-30-2018, 05:15 PM
  #53
utah997
Circles are Hard
utah997's Avatar
It's where we burn the dead hookers.
utah997 is offline
Old 08-30-2018, 05:17 PM
  #54
KarlK
CF Senior Member
KarlK's Avatar
Nice, personally, I like burning them alive...and record their screams and play them back on Halloween for the trick-or treaters
KarlK is offline
Old 08-30-2018, 05:24 PM
  #55
jh225
CF Senior Member
Liked 8 Times in 5 Posts
St. Jude Donor '14
The Camaro could have used an exhaust stack and a couple of fans too. Just sayin'.....................
jh225 is offline
Old 08-30-2018, 05:28 PM
  #56
snide
CF Senior Member
snide's Avatar
Location: You can lead a person to knowledge, but you can't make him think. - snide The problem with the gene
Liked 150 Times in 61 Posts
CI 4-5-7-8-9-10 Veteran
Ooooooh, nice burn!
snide is offline
Old 08-30-2018, 06:26 PM
  #57
Lee C
CF Senior Member
Lee C's Avatar
Liked 61 Times in 36 Posts
Originally Posted by snide View Post
Whatever happened to Lars?
Staying away from the sugar
Lee C is offline
Old 08-30-2018, 06:28 PM
  #58
mtnman
CF Senior Member
mtnman's Avatar
Liked 30 Times in 12 Posts
St. Jude Donor '17-'18
Ooooooh, nice burn!
mtnman is offline
Old 08-30-2018, 07:02 PM
  #59
Der Flieger
CF Senior Member
Der Flieger's Avatar
Liked 18 Times in 6 Posts
Meth-cooking shack? Okay then.
Der Flieger is offline
Old 08-30-2018, 07:25 PM
  #60
Lee C
CF Senior Member
Lee C's Avatar
A place to bake his own donuts for Halloween
Lee C is offline
Quick Reply: Backyard Project
Sponsored Ads
Vendor Directory
Contact Us - About Us - Archive - Advertising - Cookie Policy - Privacy Statement - Terms of Service
© 2019 MH Sub I, LLC dba Internet Brands
  • Ask a Question
Question Title:
Description:
