Off Topic Off Topic | Non-Corvette
Vintage road bike tire source?
Old 01-30-2019, 05:45 PM
cuisinartvette
CF Senior Member
St. Jude Donor '05
Default Vintage road bike tire source?
Older Shogun womens bike, uses a 700x250 ??tire
Says Silver Star on it.
Where I can I locate these? dont need the most pricy just one that holds air & goes round and round.
Figured theres a bunch of you on here that know the best place to buy
cuisinartvette is offline
Old 01-30-2019, 06:20 PM
63 340HP
CF Senior Member
63 340HP's Avatar
700x250 will be a very wide tire (250 mm wide, almost two feet wide). It's probably a 700x25.0 (25.0 mm wide, typical road race style tire).
If you want a wide tire, the 700c rim size is the same as a mountain bike 29-inch rim (with many wide tire sizes).
A local bicycle shop has these common sizes, as do many mail order internet shopping sites.
63 340HP is online now
Old 01-30-2019, 08:07 PM
cuisinartvette
CF Senior Member
St. Jude Donor '05
Probably the 25 its pretty skinny
Called 2 bike shops they said they dont carry them anymore, someone has to.
Old 01-30-2019, 08:18 PM
flange
CF Senior Member
flange's Avatar
St. Jude Donor '14
flange is offline
Old 01-30-2019, 08:19 PM
flange
CF Senior Member
flange's Avatar
St. Jude Donor '14
flange is offline
Old 01-30-2019, 09:01 PM
63 340HP
CF Senior Member
63 340HP's Avatar
https://www.biketiresdirect.com/prod...t-ii-wire-bead
https://www.biketiresdirect.com/prod...tire-wire-bead
Pick your width under the specs tab, as they are cheap. 25 mm is the most popular stock width, sometimes resulting in a backorder wait.
Current thought is to use a wider tire for comfort while training, and a set of skinny tires for road competition. A 28 mm will be more comfortable.
Old 01-30-2019, 09:06 PM
outrunm
CF Senior Member
outrunm's Avatar
St. Jude Donor '06
I'm thinking it says 25c not 250. On an old tire it may not be completely legible. You can pick one up anywhere, but if you are in doubt, you can take it to a bike shop.
outrunm is offline
Old 01-31-2019, 12:58 PM
Derrick Reynolds
CF Senior Member
Derrick Reynolds's Avatar
St. Jude Donor '13-'14-'15, '17-'18
A little math trouble here, but this is generally right. There are about 25.4 mm in an inch, so a 250 mm wide tire would be a little under 10 inches wide, not 2 feet. Not that it matters, since both are ridiculously wide.
A 25 mm tire will be about an inch, this was a common size on older racing bikes. For comparison, my 1981 Schwinn road bike came with 1 1/4" wide tires, but it is a road bike, so I would expect somewhat wider tires. 700C diameter was pretty much universal for any non-American manufacturer until the 1990s, when even the "American" brands changed from 27 inch to 700C. It is actually getting harder to find 27" tires now, which is what I run on my Schwinn. Of course, changing my wheels to 700C would be easy enough if I can't get them any more.
If you have trouble, contact Steve at The Bike Stand: http://thebikestand.com/
He stocks a lot of stuff for vintage bikes as a lot of his customers are into them. He is fine with doing business over the phone or email and shipping stuff.
Derrick Reynolds is offline
Old 01-31-2019, 01:16 PM
smwillis
Junior Member
CST makes a pile of 700x25 tires most at around 20 dollars each
smwillis is offline
Old 01-31-2019, 01:27 PM
jim2527
CF Senior Member
jim2527's Avatar
Brakes may not line up.
jim2527 is online now
Old 01-31-2019, 01:36 PM
Derrick Reynolds
CF Senior Member
They won't, I'll have to adjust the brake pads.
Old 01-31-2019, 02:21 PM
SilverC1
CF Senior Member
SilverC1's Avatar
Yeah, 700x25 is a very common tire size. Maybe 700x23 is a bit more common for road bikes, but certainly 700x25 is readily available. Maybe the store you talked to thought you were insisting on the same brand of tire as before? Plenty of good brands out there - I have been using Continental Gatorskins on my road bike, as they are pretty good in terms of puncture-resistance (at the expense of a few grams of weight).
The harder things to find are old 27" x 1", or 1 1/8" tires, for old-school Raleighs and Schwinns, from the 1960's and 1970's. Especially if you want that look of the original "gum wall" tires that those old "10 speed" bikes had.
I have an old Raleigh that I just use on a trainer stand, and I was able to find some Kenda 27" x 1 1/8" tires, that even had the "gum wall"....
SilverC1 is offline
Old 01-31-2019, 02:25 PM
smwillis
Junior Member
I own a bicycle shop and always have a few 27x1 1/4" gum tires in stock. sometimes I even have the 27x1 1/8" but any shop can get them for you. thebikestand.com
smwillis is offline
Old 01-31-2019, 04:36 PM
Derrick Reynolds
CF Senior Member
For those who didn't put it together, this ^^^^^^^ is Steve from The Bike Stand I mentioned in an earlier post. He is undoubtedly the "go to" guy for anything for a vintage bicycle around here, and probably a lot further than that!
Old 01-31-2019, 10:48 PM
Bikespace
CF Senior Member
Bikespace's Avatar
No photo of the bike? 80's vintage Shogun, made in Japan?
Try searching " 700c x 25 " on Amazon. You'll find stuff like this:
https://amzn.to/2SmDVPi
or the Gatorskins that were mentioned.
Wire beads (such as this example) will ship flat. Kevlar beads can be folded, but Amazon Prime doesn't care either way.
For old-timey service and obscure bike parts, try Harris Cyclery:
https://www.harriscyclery.net/produc...01/tires-1103/
Bikespace is offline
Old 02-01-2019, 05:29 AM
jim2527
CF Senior Member
jim2527's Avatar
Steve, if you ever have any bike related questions or need an obscure tool send me a pm. I have all kinds tools and crazy mechanic skills.
Jim aka miamijim on the bikeforum
Old 02-08-2019, 12:59 PM
cuisinartvette
CF Senior Member
St. Jude Donor '05
Ill contact him.
Think a road type tire would be best, no racing going on here just around the neighborhood type stuff.
Yup, Ill try and get some pics, in super nice shape just a little dusty.Plan on doing a light resto wont take much
Theres about an index fingers space between the top of tire and the caliper, can someone recommend a non race type tire? Nothing high end just holds air and is safe.
Old 02-08-2019, 01:18 PM
roadbike56
CF Senior Member
Support Corvetteforum!
roadbike56's Avatar
St. Jude Donor '16-'17
Ill contact him.
Continental Gatorskin. Good tire for resisting punctures while still having good rolling characteristics. BTW 700 X 25C is the most common size road bike tire.
roadbike56 is offline
Old 02-08-2019, 01:38 PM
roadbike56
CF Senior Member
roadbike56's Avatar
BTW A Shogun with 700C tires was not a bottom end, entry level bike. 700C indicates a better, either a upper entry level or a mid level bike. Probably made with double butted, chromoly steel. Possibly Tange Infinity or Tange 2. There should be a decal on the seat tube stating what tubing was used. Bottom end bikes had 27" tires, not 700C. Would certainly like to see pics.
PS And now you know where my CF handle came from.
Old 02-11-2019, 11:20 AM
cuisinartvette
CF Senior Member
St. Jude Donor '05
Ill get some pics today it is super lite and all original.
Sure would like to find some tires that arent the race only type. Need to order asap nothing in town here.
Quick Reply: Vintage road bike tire source?
Sponsored Ads
Vendor Directory
Contact Us - About Us - Archive - Advertising - Cookie Policy - Privacy Statement - Terms of Service
© 2019 MH Sub I, LLC dba Internet Brands
  • Ask a Question
Question Title:
Description:
