Go Back  CorvetteForum - Chevrolet Corvette Forum Discussion > Off Topic > Off Topic
Reload this Page >
C8 makes Front Page of Drudge Report...
Off Topic Off Topic | Non-Corvette
Old 03-13-2019, 07:28 PM
Tennis & Golf Nut
CF Senior Member
Tennis & Golf Nut's Avatar
Default C8 makes Front Page of Drudge Report...
Tennis & Golf Nut is offline
Old 03-13-2019, 07:35 PM
Silverback51
CF Senior Member
Silverback51's Avatar
Read an article about that earlier today. The frame is flexing causing the engine cover glass to break. And at least in the article I read they are going to provide flexible attach points for the glass, not fix the frame issue. Talk about a band aid fix.
Silverback51 is offline
Old 03-13-2019, 08:13 PM
pewter99
Admin
Support Corvetteforum!
pewter99's Avatar
Pilot of Beer Force 1
Tampa Regional Coordinator
CI 4-5-6-7-8 Veteran
Organizer St. Jude Fundraiser
I believe in the Beer Fairy
[GM] normal wear, not warranty issue [/GM]
pewter99 is offline
Old 03-13-2019, 10:02 PM
Tennis & Golf Nut
CF Senior Member
USA Today picked this up also: https://www.usatoday.com/story/money...​​
Old 03-13-2019, 10:31 PM
kingpin111
CF Senior Member
kingpin111's Avatar
Mechanical problems are easily fixed.
The big problem is this...
One last nondescript problem remained, described only as a butting of heads between the design and engineering teams
design(younger)
engineers(older)
These 2 groups need to work together. If the old grey hair GM brass gets involved they will **** it up even more.
kingpin111 is offline
Old 03-13-2019, 10:38 PM
04 commemorative
CF Senior Member
04 commemorative's Avatar
St. Jude Donor '17
04 commemorative is offline
Old 03-13-2019, 10:42 PM
ojm
CF Senior Member
ojm's Avatar
Great news Not.
ojm is offline
Old 03-13-2019, 10:52 PM
sublime1996525
CF Senior Member
sublime1996525's Avatar
Bahahaha. Chevy for the muthafuckin win.
sublime1996525 is offline
Old 03-13-2019, 10:55 PM
Z51JEFF
CF Senior Member
Z51JEFF's Avatar
Location: Fremont Ca. I will do No business with ANY company that boycotts Arizona.
This is GM,canít expect much.
Z51JEFF is offline
Old 03-13-2019, 11:04 PM
FourPennyDoug
CF Senior Member
FourPennyDoug's Avatar
Based on that quote kingpin posted, about the battle between design and engineering, is it possible a flexible attach point was the only fix available without compromising design?
Interesting nonetheless, did the article mention the failure rate for test cars?
FourPennyDoug is online now
Old 03-14-2019, 12:20 AM
LarsAtTheBeach
CF Senior Member
LarsAtTheBeach's Avatar
St. Jude Donor '08-'09-'10
Not of interest at an ownership level.
So, meh
LarsAtTheBeach is offline
Old 03-14-2019, 07:11 AM
Jughead
Senior Member since 1492
Jughead's Avatar
Location: 1.Just because I'm paranoid doesn't mean people aren't out to get me... 2.Build the WALL!
St. Jude Donor '09
hmmmm, you'd think an engineer would be able to address the frame bending.
Jughead is offline
Old 03-14-2019, 07:36 AM
War Eagle ZO6
Loser Sr.
War Eagle ZO6's Avatar
St. Jude Donor '09-'10, '14, '16-'17
GM is the new Hyundai of the 80s. Junk.
War Eagle ZO6 is offline
Old 03-14-2019, 08:54 AM
Hurricane
CF Senior Member
Hurricane's Avatar
Cruise-In I Veteran
What did they do, bring back the team that put together the Fiero?
Hurricane is offline
Old 03-14-2019, 09:03 AM
K-Spaz
CF Senior Member
K-Spaz's Avatar
Location: Central PA. My AR-15 identifies as a muzzleloader
Well, the fact is, no matter what you put together, there's going to be flex. It's called physics. The problem isn't that the frame flexes any more than any other car, (of similar hp) it's that the design people insist upon unnecessary glass.
Take note when you watch top fuel'ers, they don't have a glass window in the center of the chassis.
K-Spaz is offline
Old 03-14-2019, 09:24 AM
chaase
CF Senior Member
chaase's Avatar
St. Jude Donor '12
The car was pumping out 900-1000hp, and who knows how much torque. There will be flex.
chaase is offline
Old 03-14-2019, 09:35 AM
Range_Rat
CF Senior Member
Range_Rat's Avatar
Frame flexing in a tight corner under high load ... what could go wrong ???
Range_Rat is offline
Old 03-14-2019, 10:25 AM
Rky Mtn C6
CF Senior Member
Rky Mtn C6's Avatar
Like they say "Never buy a first year car."
Rky Mtn C6 is offline
Old 03-14-2019, 10:26 AM
STANG KILLA SS
CF Senior Member
STANG KILLA SS's Avatar
anybody that came from an Fbody knows the simple fix.
subframe connectors..
STANG KILLA SS is offline
Old 03-14-2019, 10:35 AM
chaase
CF Senior Member
chaase's Avatar
St. Jude Donor '12
Corvettes are full frame cars. They may need some cross bracing or stiffening in the area.
chaase is offline
Quick Reply: C8 makes Front Page of Drudge Report...
Sponsored Ads
Vendor Directory
Contact Us - About Us - Archive - Advertising - Cookie Policy - Privacy Statement - Terms of Service
© 2019 MH Sub I, LLC dba Internet Brands
  • Ask a Question
Question Title:
Description:
