Go Back  CorvetteForum - Chevrolet Corvette Forum Discussion > Off Topic > Off Topic
Reload this Page >
AND NOW - HOw do those Jet engines REVERSE upon landing?
Off Topic Off Topic | Non-Corvette
Old 03-14-2019, 07:56 AM
dvarapala
Making CFOT Great Again
Support Corvetteforum!
dvarapala's Avatar
Liked 69 Times in 29 Posts
Originally Posted by VatorMan View Post
According to FPD, you've now killed everyone on board because you've "unsettled" the aircraft.
According to DaNN, you've also pivoted the rear wheels off the ground because you've "cobbed" the brakes.
dvarapala is offline
Old 03-14-2019, 09:43 AM
ptindall
CF Senior Member
ptindall's Avatar
Liked 36 Times in 19 Posts
ptindall is offline
Old 03-14-2019, 09:55 AM
Super Nova
CF Senior Member
Super Nova's Avatar
Location: 63 Nova Pro Street I'm not as think as you stoned I am
Liked 0 Times in 0 Posts
St. Jude Donor '03
Does the braking system work on a treadmill???
Super Nova is offline
Old 03-14-2019, 10:21 AM
zsr22
CF Senior Member
BCS Bet for St. Jude '09-'10-'11, '15
Some questionable explanations in here. I'm waiting until Gixxer weighs in before determining the correct answer.
zsr22 is offline
Old 03-14-2019, 10:57 AM
FiveVettes
CF Senior Member
Liked 14 Times in 12 Posts
What chiefttp said.
FiveVettes is offline
Old 03-14-2019, 11:01 AM
JetMechZ16
CF Senior Member
Liked 32 Times in 10 Posts
They don't make any straight jet engines anymore. At least not for modern aircraft.
JetMechZ16 is offline
Old 03-14-2019, 11:31 AM
VegasJen
CFOT Attention Whore
VegasJen's Avatar
Liked 59 Times in 20 Posts
Damn it!
Originally Posted by dvarapala View Post
Modern aircraft have a special treadmill that they deploy below the wheels on landing which makes the plane stop.
Beat me to it!
VegasJen is offline
Old 03-14-2019, 12:03 PM
Silverback51
CF Senior Member
Silverback51's Avatar
Liked 32 Times in 7 Posts
Originally Posted by jcsperson View Post
These pictures show what is happening rather well.
What has changed in the last 30+ years is the engines now have a High Bypass Ratio which means that up to 70+% of the thrust of the engine comes from the air that bypasses the actual engine. That is why the cowls are so much larger than the old engines as seen in the second picture above. Hell, the engine cowl on a 777 is as big in diameter as the fuselage of a 737. The HBR engines are also much quieter than the old engines because of all the airflow around them muffles the noise.
The old jet engines used the clamshell to redirect the engine thrust as shown in picture 2 above. All the others show what is happening when the bypass air is redirected to slow the aircraft.
Silverback51 is offline
Old 03-14-2019, 12:11 PM
grandpawmoses
CF Senior Member
grandpawmoses's Avatar
Liked 68 Times in 33 Posts
Gay engines?
grandpawmoses is offline
Old 03-14-2019, 12:24 PM
JetMechZ16
CF Senior Member
Originally Posted by grandpawmoses View Post
Gay engines?
Turbo jets, turbo fans, turbo props, turbo shafts. The majority of passenger/airline winged aircraft are turbo fans and the bypass air on these turbo fans has grown as Silverback has pointed out.
The last straight jet engine that I worked on was in the EA6B which was a Pratt & Whitney J52-P-408A like the one pictured here.
Just for you though, here's the Turbo ghey engine.
Old 03-14-2019, 12:48 PM
Grumpy
MONARTOR
Grumpy's Avatar
Location: What I know, is dwarfed by what I pretend to know
Liked 35 Times in 16 Posts
Cruise-In 5-6-7-8 Veteran
St. Jude '03-'04-'05-'06-'07-'08-'09-10-'11-12-'13-'14-'15-'16-17-'18
they just run the treadmill backwards
Grumpy is offline
Old 03-14-2019, 01:03 PM
VegasJen
VegasJen's Avatar
Well since you mentioned the distinction, could you explain the difference between a "jet" engine versus a turbofan or turboprop in language even an ignoramus can understand?
VegasJen is offline
Old 03-14-2019, 01:07 PM
  #33
Meh
CF Senior Member
Meh's Avatar
Liked 36 Times in 21 Posts
As I understand it, a jet's thrust is from the exhaust only. Turbofans and turboprops use the shaft at the center of the engine to spin a fan or propeller to also make thrust.
Jet:
Turboprop:
Turbofan:
Meh is offline
Old 03-14-2019, 02:49 PM
  #34
VegasJen
VegasJen's Avatar
Jet:
Turboprop:
Turbofan:
OK, so I get the "jet" engine. No problem.
I kind of thought the turboprop was as described. I assume that's like the engines for something like the C-130 were it's a jet engine that drives the props. Correct me if I'm wrong.
Now, on to the turbofan. So is that what a conventional commercial airliner uses? Is the jet engine actually providing any significant thrust? Or is the fan the primary source of thrust?
VegasJen is offline
Old 03-14-2019, 02:54 PM
  #35
Silverback51
CF Senior Member
On all Airbus and Boeing commercial planes they use turbofan engines. As a rule of thumb you can assume that 70% of the thrust comes from the fan and the remaining 30% comes from the jet engine.
Old 03-14-2019, 03:02 PM
  #36
VegasJen
VegasJen's Avatar
OK. So what's the advantage as opposed to a straight jet engine? More efficiency/economy? Better power to weight? Complexity?
VegasJen is offline
Old 03-14-2019, 03:06 PM
  #37
abusdriver
CF Senior Member
abusdriver's Avatar
Liked 35 Times in 20 Posts
Jet engine operation simplified:
SUCK - SQUEEZE - BLOW - GO!
abusdriver is offline
Old 03-14-2019, 03:13 PM
  #38
SilverC1
CF Senior Member
SilverC1's Avatar
Liked 11 Times in 9 Posts
A friend of mine, back in HS (early 1970's) had a jet boat, that was maybe 17 feet long, but had an Olds 455 engine. Being a jet boat, you could instantly put it into reverse (as this was just re-directing the outlets under the boat, to face forward). It was incredible how fast that thing would come to a stop. (And top speed was not bad, either, over 65, IIRC...)
SilverC1 is offline
Old 03-14-2019, 03:15 PM
  #39
Silverback51
CF Senior Member
The thrust rating of a 777 engine is in excess of 100,000 pounds. It would take a very large pure jet engine to produce that thrust. Also the air from the fan significantly quiets the roar of the jet engine. Also a lot of time and effort is input into the design of the chevrons where the jet exhaust and the fan air meet. Once again this is to make them quieter.
So they are more efficient, quieter, and have a better power to weight ratio. The only downside is that they are more complex, but in the end not that much.
Old 03-14-2019, 03:30 PM
  #40
JetMechZ16
CF Senior Member
While this engine is technically a turbo fan not much additional thrust is provided by the fan. The actual bypass air area is no where near that of a commercial airliner. I'm just showing this as an example of the wide variety of turbofans that are out there.
Quick Reply: AND NOW - HOw do those Jet engines REVERSE upon landing?
Sponsored Ads
Vendor Directory
Contact Us - About Us - Archive - Advertising - Cookie Policy - Privacy Statement - Terms of Service
© 2019 MH Sub I, LLC dba Internet Brands
  • Ask a Question
Question Title:
Description:
