Go Back  CorvetteForum - Chevrolet Corvette Forum Discussion > Off Topic > Off Topic
Reload this Page >
AND NOW - HOw do those Jet engines REVERSE upon landing?
Off Topic Off Topic | Non-Corvette
Old 03-14-2019, 03:52 PM
  #41
JetMechZ16
CF Senior Member
JetMechZ16's Avatar
Here is a TF34 engine produced by GE it goes in an S3 Viking you can see a much larger fan on this engine.
JetMechZ16 is offline
Old 03-14-2019, 04:19 PM
  #42
Moderator
Support Corvetteforum!
St. Jude Donor '03-'04-'05-'06-'07-'08-'09-'10-'11-'12-'13-'14-'15-'16-'17-'18-'19
Interesting video above explaining the reverse thrust. Thanks and learned something new today.
Vetteman Jack is online now
Old 03-14-2019, 04:52 PM
  #43
Voytek
CF Senior Member
Voytek's Avatar
Amazing how plane threads always take off on this forum.
Treadmill or not
Voytek is offline
Old 03-14-2019, 04:57 PM
  #44
chiefttp
CF Senior Member
chiefttp's Avatar
VegasJen,
The newer turbo-fan engines are also referred to as a Hign bypass engine. What this means is a portion of the thrust developed by the engine “Bypasses” the hot portion of the engine, ie. the compressors, combustion chambers and turbine sections in the rear. The first generation jets, also referred to a pure jets only included the hot sections. One day somebody pretty smart figured out that if you added a large fan blade out in front of all this rapidly rotating mass and cowled this fan so the thrust was directed around the engine, not through it, it was creating a large benefit for a small penalty. During the 60’s the fan became much larger and the High Bypass engine was perfected. A by product of this engine, as Silverback and others have stated, is it’s much quieter and way more fuel efficient. The reason it’s quieter is the noise developed from a jet originates from the very hot gasses escaping out of the rear of the jet into the very cold air, the temp difference is what creates the loud sound. With the high by pass engines the hot core gases are totally enveloped by the cool fan air that bypasses combustion, so the sound is muffled by a cylinder of cool air from the bypass air.
chiefttp is offline
Old 03-14-2019, 05:20 PM
  #45
ZeusC6
CF Senior Member
ZeusC6's Avatar
Originally Posted by mchar View Post
I know some planes have those shields that re- direct flow to brake.
I see now the Jet Engines go in Reverse.
'Splain me that -
example -3:20 a 747 landing -
https://www.youtube.com/watch?v=9fGQL7rBH8Q
you can see the sides open up at the 3:20 mark which is when you see the spray move forward you're referencing
ZeusC6 is offline
Old 03-15-2019, 02:22 AM
  #46
Big Jay E
CF Senior Member
Thought it was interesting that weight on the wheels allow the reverse thrusters to activate. Apparently the early ones didn't have this safety feature. Years ago there was a crash of a Lauda Air plane in Asia. The investigation started that the reverse thrusters engaged in mid flight.
Big Jay E is online now
Old 03-15-2019, 09:42 AM
  #47
chiefttp
CF Senior Member
chiefttp's Avatar
Big Jay E,
My explanation of the weight on wheels function was simplified for my post. There are a few different systems used on aircraft to ensure the thrust reversers don’t activate in flight. Most aircraft do have a “ weight on Wheels” / air ground mode system that allows certain systems to operate only in the Air or on the ground...Other jets, like the one in my avatar can deploy the thrust reversers in flight, the DC-8 could also. In the case of the C-17 (my avatar) we could deploy all 4 reversers and descend at 20,000 ft/minute. It came in handy at times flying into a combat zone, but you better be aware of what’s happening when you execute this tactic.
chiefttp is offline
Old 03-15-2019, 02:58 PM
  #48
Capt. Shark
CF Senior Member
Capt. Shark's Avatar
Location: Into the Mystic And yet, despite the look on my face, you're still talking TN
St. Jude Donor '09-'10-'11-'12-'13-'14-'15-'16-'17-‘18
Originally Posted by chiefttp View Post
Big Jay E,
wheeeeeeeeee
Capt. Shark is offline
Old 03-15-2019, 03:42 PM
  #49
Meh
CF Senior Member
Meh's Avatar
That sounds like a wild ride. I'd love to ride along while they do that.
Meh is offline
Old 03-15-2019, 11:28 PM
  #50
F4Gary
CF Senior Member
F4Gary's Avatar
2018 C3 of Year Finalist
2016 C3 of the Year Finalist
Originally Posted by abusdriver View Post
Jet engine operation simplified:
SUCK - SQUEEZE - BLOW - GO!
No..... Suck, squeeze, bang, blow.
On the 727, F100, and MD80 we used to use the reversers to back off the gate instead of using a tug.
F4Gary is online now
Old 03-15-2019, 11:58 PM
  #51
jprop
CF Senior Member
jprop's Avatar
I was standing at the gate one day, looking out the window as our plane was taxiing in. A passenger came over to me and said, "You know, I've always wondered...Are those planes front wheel drive or rear wheel drive?" I was dumbfounded and the only thing I could come up with was, "Neither. They're 3 wheel drive." The pax just nodded his head and slowly walked away.
jprop is offline
Old 03-16-2019, 06:50 AM
  #52
slewfoot1956
CF Senior Member
slewfoot1956's Avatar
St. Jude Donor '14
Big Jay E,
I'm just curious, is this what Nasa flyers do when they go up for some weightlessness training floating around the plane?
slewfoot1956 is offline
Old 03-16-2019, 11:23 AM
  #53
jcsperson
CF Senior Member
jcsperson's Avatar
NC Events Coordinator
No. They fly a parabolic arc from a climb into a descent.
It's actually a very low speed maneuver as the aircraft nears the top of the arc.
jcsperson is offline
Old 03-16-2019, 03:34 PM
  #54
ThePirate
CF Senior Member
ThePirate's Avatar
A jet engine works on the exact principal as a fart, except you can't reverse a fart. You're welcome.
ThePirate is offline
Old 03-16-2019, 03:42 PM
  #55
dvarapala
Making CFOT Great Again
dvarapala's Avatar
Why would you want to?
dvarapala is offline
Old 03-16-2019, 05:37 PM
  #56
F4Gary
CF Senior Member
F4Gary's Avatar
The Space Shuttle pilots used to train in a Gulfstream G2 that could go full reverse in flight to simulate the descent rate of the shuttle prior to landing.
Old 03-16-2019, 06:32 PM
  #57
VegasJen
CFOT Attention Whore
VegasJen's Avatar
As I recall at one point someone said of the shuttle that it didn't fly back to earth, it fell at an angle.
VegasJen is online now
Old 03-16-2019, 09:30 PM
  #58
Capt. Shark
CF Senior Member
About the glide ratio of one of these
Old 03-21-2019, 09:50 PM
  #59
mchar
CF Senior Member
Chief you have educated me and others with this thread. I appreciate it more than you know - I'm the OP!!
CFOT, I doubt there is a forum anywhere that can teach us things about anything in the world like CFOT does -
Airplanes Chief and ROTORHEAD - what?? -Fishing - Crabr1 - Annuities -777 - Real Estate - T+G Fan... and on and on...
mchar is offline
Old 03-21-2019, 10:10 PM
  #60
abusdriver
CF Senior Member
abusdriver's Avatar
And sometimes they street race...er...airport race...
abusdriver is offline
Quick Reply: AND NOW - HOw do those Jet engines REVERSE upon landing?
Sponsored Ads
Vendor Directory
Contact Us - About Us - Archive - Advertising - Cookie Policy - Privacy Statement - Terms of Service
© 2019 MH Sub I, LLC dba Internet Brands
  • Ask a Question
Question Title:
Description:
