Go Back  CorvetteForum - Chevrolet Corvette Forum Discussion > Off Topic > Off Topic
Reload this Page >
The Best Ratchet you will ever own
Off Topic Off Topic | Non-Corvette
Old 03-14-2019, 11:23 AM
wadenelson
CF Senior Member
wadenelson's Avatar
Default The Best Ratchet you will ever own
This thing. A swivel head 3/8. I suggest buying two, a long handled one and a short one.
It'll make you a whole lot faster turning bolts. You break the bolt/nut loose at 90 degrees like a regular wrench, then twist the handle till it's like a screwdriver and spin nuts and bolts off faster than some air ratchets.
I saw a guy using one ten years ago and bought one off the truck the same day. I now own several of them, but the Snappy is the best.
I later noticed, doing some re-work the "other guy" torqued everything a bit higher than I did, I realized it was because his "go to" ratchet had a 10" (appx) handle and mine had a 6". We were both probably applying the same amount of force but...he had a longer lever.
I get away with using the 6" ratchet 99% of the time. It really works great in confined spaces as well.
If you ain't got one of these in your box, try it, and you can send me a thank you note later.
My biggest time-saving tools.
wadenelson is offline
Old 03-14-2019, 12:09 PM
Gordon Shumway
CF Senior Member
Gordon Shumway's Avatar
My biggest time saving tools.
Gordon Shumway is offline
Old 03-14-2019, 12:10 PM
Jughead
Senior Member since 1492
Support Corvetteforum!
Jughead's Avatar
Location: 1.Just because I'm paranoid doesn't mean people aren't out to get me... 2.Build the WALL!
St. Jude Donor '09
must have been a n0ob prison break somewhere.
Jughead is offline
Old 03-14-2019, 12:11 PM
arthursc2
CF Senior Member
arthursc2 is offline
Old 03-14-2019, 12:15 PM
TorchRedRocket
CF Senior Member
TorchRedRocket's Avatar
How many years did you finance that ratchet for?
TorchRedRocket is offline
Old 03-14-2019, 12:21 PM
Nowhere Man
CF Senior Member
Nowhere Man's Avatar
2015 C2 of Year Finalist
Been using one for years
Nowhere Man is offline
JasonAndrew
CF Senior Member
JasonAndrew's Avatar
I am a fan of nice ratchets, BUT have never had to use one of that style yet. My favorite is a 3/8 polished stubby craftsman that swivels. It fits in the palm of my hand.
JasonAndrew is offline
Old 03-14-2019, 12:28 PM
ptindall
CF Senior Member
ptindall's Avatar
How would you know anything about using tools if you can't even do a brake job on an X3?
ptindall is offline
Old 03-14-2019, 12:29 PM
Humanoid 2.0
CF Senior Member
Humanoid 2.0's Avatar
Cruise-In VII Veteran
St. Jude Donor '05-'06-'07-'08-'09-'10-'11-'12-'13-'14-'15-'16-'17-'18
Are you sure you are talking about your ratchet? Or were you comparing something else?
Humanoid 2.0 is offline
Old 03-14-2019, 12:33 PM
wadenelson
CF Senior Member
wadenelson's Avatar
How do you do a brake job on an X3 without a factory scan tool to retract the electric parking brake? Serious question.
Old 03-14-2019, 12:39 PM
TurboTnZ06
CF Senior Member
TurboTnZ06's Avatar
The 90* scratch awl is one of the best tools. I also like angle bent needle nose pliers paired with non swivel rachets. I grabbed a set of 90 tooth Kobalt rachets for the boat, and they are very nice for cheap. Got 1/4, 3/8 and 1/2 all for $30 at Lowes. They look the same as the Snapons next to them in the drawer.
TurboTnZ06 is offline
Old 03-14-2019, 12:54 PM
TorchRedRocket
CF Senior Member
Old 03-14-2019, 01:27 PM
Meh
CF Senior Member
Meh's Avatar
**** that ****. Get some power tools, peasant.
Meh is offline
Old 03-14-2019, 01:31 PM
RandolphB
CF Senior Member
RandolphB's Avatar
Got those types from Harbor Freight 10 years ago, less than 15 bucks a piece with a lifetime guarantee. Didn't have to take out a second on the house to buy them, and they're still doing just fine. Many cars and aircraft have benefited from their use.
RandolphB is offline
Old 03-14-2019, 01:45 PM
ptindall
CF Senior Member
ptindall's Avatar
ptindall is offline
Old 03-14-2019, 02:29 PM
wadenelson
CF Senior Member
wadenelson's Avatar
Torch, my ratchets are Snappy, my big air tools IR, my sockets and combos are Craftsman, and so on, on down the line to pry bars and other cheap bullshit from Hazardous Freight.
Many of my "small" air tools (die grinders, angles, cutoffs, 3/8 ratchets ...) came from pawn shops where I bought them for ten cents on the dollar. Good ones.
What I don't own are multi-thousand dollar toolboxes. A bottom-end ball-bearing toolbox works just fine for me. My dick is big enough I don't need to impress folks with a shiny red box.
Unless I can buy 'em on the side of the road for $500 plus a new set of casters, that is.
https://www.corvetteforum.com/forums...-birthday.html
Old 03-14-2019, 02:37 PM
KarlK
CF Senior Member
KarlK's Avatar
72 tooth ratchet?
go 120 tooth with a GearWrench ratchet
KarlK is offline
Old 03-14-2019, 02:47 PM
MAD IN NC
CF Senior Member
MAD IN NC's Avatar
Crowd Plow For Now
.... wouldn’t be caught dead w BMW. More Voys style....
If I was forced to own one -call the guy
MAD IN NC is offline
Old 03-14-2019, 02:59 PM
wadenelson
CF Senior Member
wadenelson's Avatar
Originally Posted by KarlK View Post
72 tooth ratchet? Go 120 tooth with a GearWrench ratchet
Hey, question about that. Obviously 120 teeth lets you swing it in smaller spaces.
But is it a trade-off between strength and # of teeth? As in a 72 tooth ratchet can handle more torque without breaking teeth than a 120?
I guess the answer is to have both and use the right one, eh?
I've had the Snap-On rebuilt once and it's due again. Not due to broken teeth but it binds when I try to shift from Forward to Reverse. Probably just needs cleaned/lubed.
Cheers
Old 03-14-2019, 03:20 PM
KarlK
CF Senior Member
KarlK's Avatar
Cheers
more teeth engaged = more strength
KarlK is offline
Quick Reply: The Best Ratchet you will ever own
Sponsored Ads
Vendor Directory
Contact Us - About Us - Archive - Advertising - Cookie Policy - Privacy Statement - Terms of Service
© 2019 MH Sub I, LLC dba Internet Brands
  • Ask a Question
Question Title:
Description:
