Go Back  CorvetteForum - Chevrolet Corvette Forum Discussion > Off Topic > Off Topic
Reload this Page >
My 8hp Masterblaster keeps tripping the fuse box
Off Topic Off Topic | Non-Corvette
Old 03-14-2019, 08:28 PM
DOOKEY
CF Senior Member
DOOKEY's Avatar
Have you tried not using it?
DOOKEY is offline
Old 03-14-2019, 09:19 PM
Meh
CF Senior Member
Meh's Avatar
I had to look up the device in question. That's a lot of money for something to dry off your car. You must have an impressive wax collection.
Meh is offline
Old 03-14-2019, 09:23 PM
tcotta411
CF Senior Member
Wax collection? No. Polish collection, yes.
Actually my car has been coated with CQuartz. No real need for polishing or waxing.
Thanks for the responses. I now know I need to seek the services of an electrician.
tcotta411 is offline
Old 03-14-2019, 09:27 PM
BOTYNV1
CF Senior Member
BOTYNV1's Avatar
St. Jude Donor '09-'10-'11-'12-'13-'14-'15-'16-'17-'18-'19
Originally Posted by KenHorse View Post
Well actually, he could use an undersize extension that will limit the current draw
(but it will also make a nice heater!)
BOTYNV1 is offline
Old 03-14-2019, 09:30 PM
Meh
CF Senior Member
Meh's Avatar
Meh is offline
Old 03-14-2019, 09:32 PM
TyBoo
CF Senior Member
TyBoo's Avatar
That's what I thought until i got one. It not only dries off the car and truck, it takes off the dust accumulation the car gets sitting in the garage, cleans out the interior of the truck, cleans out the interior of the car when the top is down, cleans out the crevices in the seats and under the seats, cleans the convertible top, cleans off most of the crud that sticks to the rear end of the car, and dries my granddaughter's Golden Retriever - all without touching the surface. It works so well for the dog that she is buying one for her boyfriend to use on his truck so she has it there for the mutt.
It does take a little longer than towels to completely dry the surface, but it gets the water out that the towels can't reach and dries everything. My black car really appreciates it!
TyBoo is offline
Old 03-14-2019, 09:35 PM
tcotta411
CF Senior Member
^^^^^^ what he said^^^^^^
I had the 4hp and upgraded to the 8hp.
Never regretted it.
Old 03-14-2019, 10:42 PM
Meh
CF Senior Member
Meh's Avatar
Is it like the air version of this?
Meh is offline
Old 03-14-2019, 10:47 PM
TyBoo
CF Senior Member
TyBoo's Avatar
Close, but not quite. You do want to have a good grip on the hose when you switch it on.
There are two types of people who need the Master Blaster for drying a car: Perfectionists and lazy people. I am the latter.
TyBoo is offline
Old 03-14-2019, 11:18 PM
Meh
CF Senior Member
Meh's Avatar
Do you have a 4-prong dryer outlet (NEMA 14-30) in the vicinity of where you are working? If so, something like this might do the trick.
Amazon Amazon
Meh is offline
Old 03-15-2019, 09:28 AM
Humanoid 2.0
CF Senior Member
Humanoid 2.0's Avatar
Cruise-In VII Veteran
St. Jude Donor '05-'06-'07-'08-'09-'10-'11-'12-'13-'14-'15-'16-'17-'18
Originally Posted by FLTCRW View Post
Hi, I'm an electrical contractor, what you need is dedicated 20 amp circuit for just this piece of equipment. Don't replace electric breaker for bigger one, the breaker is sized according to wire size. Sorry I'm in Oregon
This
Humanoid 2.0 is offline
Old 03-15-2019, 11:09 AM
slow_zo6
CF Senior Member
slow_zo6's Avatar
Same here-about to sell this overrated pos. It doesn’t do that good of a job and actually takes longer than hand drying.
slow_zo6 is offline
Old 03-15-2019, 11:24 AM
  #33
ratflinger
NCM Grand Opening Veteran
Support Corvetteforum!
ratflinger's Avatar
St. Jude Donor '11, '17
Do not just change the breaker Unless you have verified 12ga wire on that circuit. Unless you spec'ed 12ga wiring the electricians that wired your house probably used 14g cause it meets code and is cheaper. You must run a 12/2 wire from the panel (where you have a 20a breaker) to a 20a outlet for that unit. Generally why it's best when building a house to run all circuits except lights as 20a.
Can you push 20a down 14ga - yes, but you increase the fire hazard.
ratflinger is offline
Old 03-15-2019, 11:29 AM
  #34
tcotta411
CF Senior Member
Only 4-prong is in the laundry room. Too far away.
Old 03-15-2019, 03:13 PM
  #35
CurtP
CF Senior Member
CurtP's Avatar
I'm calling BS on the 8hp rating.
CurtP is offline
Old 03-15-2019, 03:32 PM
  #36
PatternDayTrader
CF Senior Member
PatternDayTrader's Avatar
This is how I would handle the situation.
PatternDayTrader is offline
Old 03-15-2019, 06:25 PM
  #37
Gordon Shumway
CF Senior Member
Gordon Shumway's Avatar
If you are looking for a 20 amp circuit check your laundry room, which is likely close to the garage. The washing machine outlet should be 20 amp. Of course, you could always just look in the breaker box to find one.
Gordon Shumway is offline
Old 03-15-2019, 07:46 PM
  #38
BadUmp
CF Senior Member
BadUmp's Avatar
at about $0.05 per foot more for 12-2 I don't understand why the whole dang house isn't done with just 12-2 and just make most things 20a. People are just going to overload things anyway so take that out of the mix if possible . . .
BadUmp is offline
Old 03-15-2019, 08:44 PM
  #39
PatternDayTrader
CF Senior Member
No kidding.
Old 03-15-2019, 08:49 PM
  #40
Grumpy
MONARTOR
Grumpy's Avatar
Location: What I know, is dwarfed by what I pretend to know
Cruise-In 5-6-7-8 Veteran
St. Jude '03-'04-'05-'06-'07-'08-'09-10-'11-12-'13-'14-'15-'16-17-'18
angies list
Grumpy is offline
Quick Reply: My 8hp Masterblaster keeps tripping the fuse box
Sponsored Ads
Vendor Directory
Contact Us - About Us - Archive - Advertising - Cookie Policy - Privacy Statement - Terms of Service
© 2019 MH Sub I, LLC dba Internet Brands
  • Ask a Question
Question Title:
Description:
